Let me describe my problem first:
At work, we have an Ubuntu 14.04.1 LTS server which is obviously kinda outdated. I need to make a release upgrade and before that, there needs to be a backup. We have a Windows 2012 Server which would have enough space to store the backup. I googled and found a solution to keep the permissions, which would be lost if I just cp -a everything:
dd if=/path/to/dir bs=1G | gzip > /path/to/backup/backup.tar.gz
So in that .tar.gz file, the permissions should be kept.
My idea was it to run the dd for every dir which I needed to backup:
/etc, /home, /var
Next step would be to create a package list to reinstall all the packages. Found a solution here: (it's german but I guess you understand what they do)
apt-get create package list
After that, I should have a directory /backup/ where all the .tar.gz files and the package lists are. This dir I would copy to our Windows server and do the release-upgrade on the Ubuntu server. If the upgrade messes with the system I can easily restore everything if I run the dd with reversed if and of.
Now my question(s):
Did I miss anything (in general/directories I need to restore the System/etc)?
Is there a better way to do it?
I hope my English isn't too bad and thank you for your help.
NIMISHAN
  • 1,625
  • 20
  • 28
Holger P.
