System info
$ lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description:    Ubuntu 18.04.3 LTS
Release:    18.04
Codename:   bionic
Tried building kde connect from source
after i run
sudo apt-get build-dep kdeconnect
i get
Reading package lists... Done
Building dependency tree
 builddeps:kdeconnect : Depends: libqca2-plugin-ossl but it is not installable
Tried installing from
  1. How to Use KDE Connect with MATE on Ubuntu and Debian
  2. Install KDE Connect in Ubuntu 18.04
  3. How to install KDE connect in ubuntu 17.04?
All the mentioned unable to launch kde connect indicator or kde connect
Please guide
I suppose that you forgot to add universe repository. The kdeconnect package is located in it in all current Ubuntu versions.
You have to:
  1. add the repository with sudo add-apt-repository universe
  2. install KDE Connect with sudo apt-get install kdeconnect
N0rbert
  • 103,263
