So, I accidentally ran chmod -x / instead of what I meant to, and therefore broke a load of stuff on my server. Because of this, I can't do things like log into the normal way, and am having to use other methods.
I tried this Fix permissions of server after accidental chmod but just got tons of permission issues that look a bit like "changing permission of '/proc/sys/net/etc.." and then it still does not work. I also get this for a lot of other directories.
If you could let me know how to fix this or any other information you need, that would be great.
mook765
  • 18,644
The command chmod -x / only removes the executable bit from the root-directory. If you'd be still logged in as root, you could easily reverse the change with chmod +x /.
Obviously you are not logged in as root anymore, so you have locked out yourself from the system. This can still be fixed. I just did the same, I ran chmod -x /, closed the terminal and I broke the system, I can't even reboot.
I solved this booting from Live-USB, the problem is, that we can't use chmod to restore the correct permissions of the damaged root-filesystem because it doesn't have a name. But we know that the root-filesystem is stored as inode number 2. We can use the command debugfs to restore the correct permissions.
With lsblk | grep -v loop we can determine the device-name of the damaged filesystem.
Then we can run debugfs -w /dev/sdXY as root, take a look at my example below:
# debugfs -w /dev/sdb2
debugfs 1.44.1 (24-Mar-2018)
debugfs:  modify_inode <2>
                          Mode    [040644] 040755   # here enter correct permissions and hit enter
                       User ID    [0]               # here and in the following prompts only hit enter
                      Group ID    [0]
                          Size    [4096]
                 Creation time    [1564191527]
             Modification time    [1564191527]
                   Access time    [1567339087]
                 Deletion time    [0]
                    Link count    [24]
              Block count high    [0]
                   Block count    [8]
                    File flags    [0x80000]
                    Generation    [0x0]
                      File acl    [0]
           High 32bits of size    [0]
              Fragment address    [0]
               Direct Block #0    [127754]
               Direct Block #1    [4]
               Direct Block #2    [0]
               Direct Block #3    [0]
               Direct Block #4    [1]
               Direct Block #5    [9265]
               Direct Block #6    [0]
               Direct Block #7    [0]
               Direct Block #8    [0]
               Direct Block #9    [0]
              Direct Block #10    [0]
              Direct Block #11    [0]
                Indirect Block    [0]
         Double Indirect Block    [0]
         Triple Indirect Block    [0]
debugfs: quit                                       # here we quit
The permissions of this root-filesystem are correct now and I can reboot into the former damaged system.
mook765
  • 18,644
