I have had this on problem on different machines using Ubuntu 19.04 after recent updates, and I became intensly curious after my DVD and USB drives started having trouble mounting.
During the apt processing I see:
GDBus.Error:org.freedesktop.systemd1.UnitMasked: Unit -.mount is masked.
This message comes-up at different times. I am concerned that it has something to do with a failure for removable media to automount recently. For example:
$ sudo apt update
Hit:1 http://au.archive.ubuntu.com/ubuntu disco InRelease
Get:2 http://au.archive.ubuntu.com/ubuntu disco-updates InRelease [97.5 kB]
Get:3 http://au.archive.ubuntu.com/ubuntu disco-backports InRelease [88.8 kB]
Hit:4 https://dl.yarnpkg.com/debian stable InRelease
Ign:5 http://dl.google.com/linux/chrome/deb stable InRelease
Get:6 http://security.ubuntu.com/ubuntu disco-security InRelease [97.5 kB]
Hit:7 http://ppa.launchpad.net/danielrichter2007/grub-customizer/ubuntu disco InRelease
Hit:8 http://dl.google.com/linux/chrome/deb stable Release
Hit:10 https://packages.microsoft.com/repos/vscode stable InRelease
Hit:11 http://ppa.launchpad.net/teejee2008/ppa/ubuntu disco InRelease
Fetched 284 kB in 2s (168 kB/s)
Error: GDBus.Error:org.freedesktop.systemd1.UnitMasked: Unit -.mount is masked.
Reading package lists... Done
Building dependency tree
All packages are up to date.
After issuing a ...
$ sudo apt upgrade
... command this morning, none of my USB drives auto-mount when they are plugged-in to my laptop. I had this on my desktop yesterday (again following recent apt upgrade-ing). And I'm smelling something fishy.
Another issue that may be related is that (read-only) DVD-s can't be read correctly. First they won't mount unless I use Disks (GUI) to mount them and then VLC and dvd-backup don't seem to find the titles, etc.
Everything comes back to: "Unit -.mount is masked." (see later).
My understanding of things in the systemd world is that "-.mount" is root(/). I am looking for information to help me find a better solution that unmask-ing root.
Is there a way to put things right again?
related questions:
- Unit packagekit.service is masked
- In this case only
packagekit.serviceis reported masked.
- In this case only
- https://stackoverflow.com/questions/57778341/error-gdbus-errororg-freedesktop-systemd1-unitmasked-unit-mount-is-masked
- Is also a problem with: "
Unit -.mount is masked." - No answer as yet -- So I have done some more looking.
investigations:
I'm documenting troubleshooting I've looked at so far for this problem first before just re-enabling things before checking first?
I've done some digging because it was a surprise to me that I had things "UnitMasked" at all ... What is "masked"? From the man page --
$ man systemctrl
mask UNIT...
Mask one or more units, as specified on the command line. This will link these unit files to /dev/null, making it
impossible to start them. This is a stronger version of disable, since it prohibits all kinds of activation of the unit,
including enablement and manual activation. Use this option with care.
Which package or thing is giving me bother?
That's not a straightforward question to answer -- As I understand it the message I saw on the console was:
Which begs the question, what is: '-.mount' in this context?
Mu review of the information so far in my inquirey is/was that a 'Unit' used by a SystemD 'package' has trouble with something called "-.mount". The first thing I thought to consider was to determine what package was having issues and that is definitely something that was surprisingly less simple to do with the tools I have to hand (or that I know about). Please suggest better tools for managing and troubleshooting systemd sfuff you have some recommendations.
For me I decided to look through all the active services and see which one(s) are generating that problem. I would up making a short bash script that xargs can invoke to poke the service {} status and add some formatting:
#!/bin/bash
# file: tmp.bash
svice="${1}"
echo "------[${svice}]-----"
service "${svice}" status
echo " ======"
echo
And call this for each active service from systemd ...
service --status-all | fgrep "[ + ]" | awk -e '{ print $4 }' | xargs -i ./tmp/tmp.bash "{}" \; | less
I needed to add less to the end to avoid 22 of the automatic paging-s that the status command gives by default.
The outcome of scanning this output for "-.mount" was:
------[dbus]-----
● dbus.service - D-Bus System Message Bus
Loaded: loaded (/lib/systemd/system/dbus.service; static; vendor preset: enabled)
Active: active (running) since Wed 2019-09-11 17:32:39 AEST; 1 weeks 1 days ago
Docs: man:dbus-daemon(1)
Main PID: 1011 (dbus-daemon)
Tasks: 1 (limit: 4915)
Memory: 5.7M
CGroup: /system.slice/dbus.service
└─1011 /usr/bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation --syslog-only
Sep 20 10:32:50 4TELLT70 dbus-daemon[1011]: [system] Activating via systemd: service name='org.freedesktop.PackageKit' unit='packagekit.service' requested by ':1.6013' (uid=0 pid=23179 comm="/usr/bin/gdbus call --system --dest org.freedeskto" label="kernel")
Sep 20 10:32:50 4TELLT70 dbus-daemon[1011]: [system] Activation via systemd failed for unit 'packagekit.service': Unit -.mount is masked.
Sep 20 10:32:53 4TELLT70 dbus-daemon[1011]: [system] Activating via systemd: service name='org.freedesktop.fwupd' unit='fwupd.service' requested by ':1.367' (uid=1000 pid=9453 comm="/usr/bin/gnome-software --gapplication-service " label="kernel")
Sep 20 10:32:53 4TELLT70 dbus-daemon[1011]: [system] Activation via systemd failed for unit 'fwupd.service': Unit -.mount is masked.
Sep 20 10:36:08 4TELLT70 dbus-daemon[1011]: [system] Activating via systemd: service name='org.freedesktop.PackageKit' unit='packagekit.service' requested by ':1.6057' (uid=0 pid=24456 comm="/usr/bin/gdbus call --system --dest org.freedeskto" label="kernel")
Sep 20 10:36:08 4TELLT70 dbus-daemon[1011]: [system] Activation via systemd failed for unit 'packagekit.service': Unit -.mount is masked.
Sep 20 10:36:14 4TELLT70 dbus-daemon[1011]: [system] Activating via systemd: service name='org.freedesktop.fwupd' unit='fwupd.service' requested by ':1.367' (uid=1000 pid=9453 comm="/usr/bin/gnome-software --gapplication-service " label="kernel")
Sep 20 10:36:14 4TELLT70 dbus-daemon[1011]: [system] Activation via systemd failed for unit 'fwupd.service': Unit -.mount is masked.
Which can be summarised as the following packages:
- packagekit.service
- fwupd.service
Following that-up I found this natty little command:
systemctl list-unit-files
Which gives a HUGE list of units and status. Looking for unmasked unit-s seemed a fair question...
$ systemctl list-unit-files | fgrep "masked"
-.mount masked-runtime
boot-efi.mount masked-runtime
boot.mount masked-runtime
56 results
umountroot.service masked
x11-common.service masked
$ systemctl list-unit-files | fgrep masked | fgrep fwupd
$ systemctl list-unit-files | fgrep masked | fgrep package
And this give me 56 units to scan. None are: packagekit nor fwupd.
The unit syntax: -.mount threw me until I saw this: "with slashes changed to dashes" under .mount in the article[1] linked below:
- .mount: This unit defines a mountpoint on the system to be managed by systemd. These are named after the mount path, with slashes changed to dashes. Entries within /etc/fstab can have units created automatically.
- .automount: An .automount unit configures a mountpoint that will be automatically mounted. These must be named after the mount point they refer to and must have a matching .mount unit to define the specifics of the mount.
A key thing for me is that the dash("-") is said to represent the slash(/) in the path -- making this root.
As I understand this, then: "-.mount" is: "/" (root). Is that not so?
With this knowledge in hand I attempted the unmask and restart activity
$ sudo systemctl unmask packagekit.service
$ sudo service packagekit restart
Failed to restart packagekit.service: Unit -.mount is masked.
$ sudo systemctl restart packagekit.service
Update one
There was an Ubuntu update today. The problem persists. I have previously found that the DVD issue was to do with codec and that's resolved.
Also I am showing the listing requested
lsblk -fcat /etc/fstab
Toward the end of the upgrade there was again an error relating to umount issues.
$ sudo apt upgrade -y
Calculating upgrade... Done
The following packages will be upgraded:
bluez bluez-cups bluez-obexd e2fsprogs libbluetooth3 libcom-err2 libext2fs2 libsdl2-2.0-0 libss2 libssl1.1 netplan.io openssl
qemu-block-extra qemu-kvm qemu-system-common qemu-system-data qemu-system-gui qemu-system-x86 qemu-utils tzdata yarn
21 to upgrade, 0 to newly install, 0 to remove and 0 not to upgrade.
Need to get 13.2 MB of archives.
After this operation, 66.6 kB of additional disk space will be used.
Get:1 http://au.archive.ubuntu.com/ubuntu disco-updates/main amd64 libext2fs2 amd64 1.44.6-1ubuntu0.1 [160 kB]
Get:2 https://dl.yarnpkg.com/debian stable/main amd64 yarn all 1.19.0-1 [890 kB]
Current default time zone: 'Australia/Sydney'
Local time is now: Fri 4 Oct 00:04:06 AEST 2019.
Universal Time is now: Thu Oct 3 14:04:06 UTC 2019.
Run 'dpkg-reconfigure tzdata' if you wish to change it.
Setting up bluez (5.50-0ubuntu2.1) ...
Failed to restart bluetooth.service: Unit -.mount is masked.
invoke-rc.d: initscript bluetooth, action "restart" failed.
● bluetooth.service - Bluetooth service
Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled; vendor preset: enabled)
Active: active (running) since Thu 2019-09-19 08:26:47 AEST; 2 weeks 0 days ago
Docs: man:bluetoothd(8)
Main PID: 1451 (bluetoothd)
Status: "Running"
Memory: 2.8M
CGroup: /system.slice/bluetooth.service
└─1451 /usr/lib/bluetooth/bluetoothd
Oct 03 07:29:21 woodypear bluetoothd[1451]: Endpoint unregistered: sender=:1.15593 path=/MediaEndpoint/A2DPSource
Oct 03 07:29:21 woodypear bluetoothd[1451]: Endpoint unregistered: sender=:1.15593 path=/MediaEndpoint/A2DPSink
Oct 03 07:29:25 woodypear bluetoothd[1451]: Loading LTKs timed out for hci0
Oct 03 07:29:25 woodypear bluetoothd[1451]: Endpoint registered: sender=:1.15593 path=/MediaEndpoint/A2DPSource
Oct 03 07:29:25 woodypear bluetoothd[1451]: Endpoint registered: sender=:1.15593 path=/MediaEndpoint/A2DPSink
Oct 03 20:36:54 woodypear bluetoothd[1451]: Endpoint unregistered: sender=:1.15593 path=/MediaEndpoint/A2DPSource
Oct 03 20:36:54 woodypear bluetoothd[1451]: Endpoint unregistered: sender=:1.15593 path=/MediaEndpoint/A2DPSink
Oct 03 20:36:58 woodypear bluetoothd[1451]: Loading LTKs timed out for hci0
Oct 03 20:36:58 woodypear bluetoothd[1451]: Endpoint registered: sender=:1.15593 path=/MediaEndpoint/A2DPSource
Oct 03 20:36:58 woodypear bluetoothd[1451]: Endpoint registered: sender=:1.15593 path=/MediaEndpoint/A2DPSink
dpkg: error processing package bluez (--configure):
installed bluez package post-installation script subprocess returned error exit status 1
Setting up libss2:amd64 (1.44.6-1ubuntu0.1) ...
Setting up qemu-system-data (1:3.1+dfsg-2ubuntu3.5) ...
Setting up bluez-cups (5.50-0ubuntu2.1) ...
Setting up libbluetooth3:amd64 (5.50-0ubuntu2.1) ...
Setting up yarn (1.19.0-1) ...
Setting up libsdl2-2.0-0:amd64 (2.0.9+dfsg1-1ubuntu1.19.04.1) ...
Setting up openssl (1.1.1b-1ubuntu2.4) ...
Setting up qemu-block-extra:amd64 (1:3.1+dfsg-2ubuntu3.5) ...
Setting up qemu-system-common (1:3.1+dfsg-2ubuntu3.5) ...
Failed to restart qemu-kvm.service: Unit -.mount is masked.
Failed to try-restart qemu-kvm.service: Unit -.mount is masked.
Setting up qemu-system-x86 (1:3.1+dfsg-2ubuntu3.5) ...
Setting up e2fsprogs (1.44.6-1ubuntu0.1) ...
update-initramfs: deferring update (trigger activated)
Setting up qemu-utils (1:3.1+dfsg-2ubuntu3.5) ...
Setting up qemu-kvm (1:3.1+dfsg-2ubuntu3.5) ...
Processing triggers for man-db (2.8.5-2) ...
Processing triggers for dbus (1.12.12-1ubuntu1.1) ...
Processing triggers for libc-bin (2.29-0ubuntu2) ...
Processing triggers for systemd (240-6ubuntu5.7) ...
Processing triggers for initramfs-tools (0.131ubuntu19.1) ...
update-initramfs: Generating /boot/initrd.img-5.2.9-050209-generic
bluez
Block devices / lsblk -f:
I would have excised the snap related mounts except that this may actually be related. I have not been able to use lxd and the only install available seems to be the snap.
$ sudo lsblk -f
NAME FSTYPE LABEL UUID FSAVAIL FSUSE% MOUNTPOINT
loop0 squashfs 0 100% /snap/lxd/11985
loop1 squashfs 0 100% /snap/core/7396
loop2 squashfs 0 100% /snap/fwupd/880
loop3 squashfs 0 100% /snap/gnome-system-monitor/100
loop5 squashfs 0 100% /snap/core18/1098
loop6 squashfs 0 100% /snap/gnome-characters/296
loop7 squashfs 0 100% /snap/gnome-3-26-1604/92
loop8 squashfs 0 100% /snap/gnome-logs/73
loop9 squashfs 0 100% /snap/gnome-3-28-1804/67
loop10 squashfs 0 100% /snap/gnome-characters/317
loop11 squashfs 0 100% /snap/gnome-calculator/406
loop12 squashfs 0 100% /snap/gtk-common-themes/1313
loop13 squashfs 0 100% /snap/gtk-common-themes/1198
loop15 squashfs 0 100% /snap/gnome-3-26-1604/90
loop16 squashfs 0 100% /snap/core/7713
loop17 squashfs
loop18 squashfs 0 100% /snap/gnome-system-monitor/95
loop19 squashfs 0 100% /snap/core18/1144
loop20 squashfs 0 100% /snap/gnome-3-28-1804/71
loop21 squashfs 0 100% /snap/gnome-calculator/501
loop22 btrfs default ea3db848-1e70-4c8a-b602-66f3efXXXX
loop23 squashfs 0 100% /snap/fwupd/1023
loop24 squashfs 0 100% /snap/lxd/11964
loop25 squashfs 0 100% /snap/gnome-logs/81
sda
├─sda1 vfat 5888-2C75 1013.2M 1% /boot/efi
├─sda2 ext4 fa69a588-5a3c-4f5d-beff-d5c5f7XXXX 30.5G 46% /
├─sda3 ext4 Backup 81b6a1e3-0674-4c8c-b5ff-80010fXXXX 104.8G 46% /Backup
└─sda5 ext4 Moort c88ac1c9-9c80-4d56-9faf-5a3210XXXX 115.6G 87% /Moort
sdb
└─sdb1 btrfs zpanda 353f4608-a9be-464e-b9e5-6e53771XXX 779.3G 79% /mnt/Zpanda
sdc
└─sdc1 ntfs Xpanda 7CF02B31F02AXXX 1.5T 17% /mnt/Xpanda
sdd
└─sdd1 vfat ALEX-06 38BF-XXX 8.2G 86% /media/username/AAAAA
sde
└─sde1 exfat GGGGGG C3EC-XXX 117.2G 2% /media/username/GGGGGG
sr0
The USB labeled "GGGGGG" didn't auto-mount. It is inconsistient in this way. Sometimes it automounts, others not. It was formatted with the Ubutnu supplied exfat that come with the drives utility.
Mounts / cat /etc/fstab:
I believe the mount error refers to systemd modules not drives (however it is OK with me to discover I'm not on the right track).
$ cat /etc/fstab
# /etc/fstab: static file system information.
# Use 'blkid' to print the universally unique identifier for a
# device; this may be used with UUID= as a more robust way to name devices
# that works even if disks are added and removed. See fstab(5).
# <file system> <mount point> <type> <options> <dump> <pass>
# / was on /dev/sda2 during installation
UUID=fa69a588-5a3c-4f5d-beff-d5c5f70XXXX / ext4 errors=remount-ro 0 1
# /boot/efi was on /dev/sda1 during installation
UUID=5888-XXXX /boot/efi vfat umask=0077 0 1
# /Moort partition
UUID=c88ac1c9-9c80-4d56-9faf-5a3210XXXX /Moort ext4 defaults 0 1
/Moort/work /work none bind
# /Backup partition
UUID=81b6a1e3-0674-4c8c-b5ff-80010XXXX /Backup ext4 defaults 0 2
# /mnt/Xpanda partition
UUID=7CF02B31F0XXXX /mnt/Xpanda ntfs umask=007,fmask=137,dmask=027,uid=XXXX,gid=XXXXX,nls=utf8,utf8 0 2
# /mnt/Zpanda partition
UUID=353f4608-a9be-464e-b9e5-6e53771XXXX /mnt/Zpanda btrfs defaults 0 1
/swapfile none swap sw 0 0
references:
man systemdman sysctrl- Linux Systemd Essentials: Working with Services, Units, and the Journal
