I have a new version of gcc installed from source in my directory on a larger computer system which has another (older) version used as default. I have a few programs I need to compile using this newer version so I need to switch the version my system automatically uses somehow.
The newer gcc verion has a set of executables in gcc_9_2/bin/ that look like:
g++-9.2   gcc-9.2   gfortran-9.2
i.e with version numbers attached.
The simplest thing that occurred to me was to change $PATH so that the directory containing the newer versions was searched first, but I don't know how to do that and export just adds directories to the end of the path (which won't work). Then remove the version numbers from the executables such as gcc-9.2 to gcc and similar, though I'd be surprised if this does not cause problems.
I've looked at the answers in How to choose the default gcc and g++ version? but the first response requires sudo permissions (which I don't posses) and the second requires me to rm /usr/bin/gcc which again, I don't have permission to do.
TLDR: When I type gcc my computer uses one version of gcc, I need it to use a different version and I don't have permission to edit the directory where the old version is installed
CT1234
  • 23
You could use alias command to override a command.
alias gcc="/home/username/pathtogcc/bin/gcc"
This is often used for built-ins like ls, e. g. when using it like
alias ls="ls -l"
Croydon
  • 46
