It turns out that my GTX geForce 570 doesn't support vulkan... but I had been meddling with my drivers a lot before figuring that out.
As it stands, my computer's screen resolution is set wrong, I can't run openGL anymore, and my GPU isn't listed under "Settings" > "About" > "Graphics"
Buuuut...
If I look at the active driver under "Software & Updates" > "Additional Drivers", not only is 390 listed and selected, but it won't let me choose any other driver (if I try choosing Nouveau or 340, when I "apply changes" it pauses and then 390 becomes active once again. Rebooting doesn't help). This is still the case, even if I run
sudo apt-get purge nvidia*
And finally, I can't receive updates. The auto-updates have a number of items queued up, but if I try to update any of them, I get an error window which reads:
Check if you are using third party repositories. If so disable them, since they are a common source of problems.
Furthermore run the following command in a Terminal: apt-get install -f
Transaction failed: The package system is broken
libnvidia-ifr1-390: Depends: libnvidia-gl-390 but it is not installed
libnvidia-ifr1-390:i386: Depends: libnvidia-gl-390 but it is not installed
nvidia-driver-390: Depends: libnvidia-gl-390 (= 390.129-0ubuntu0~gpu18.04.1) but it is not installed
                   Depends: nvidia-dkms-390 (= 390.129-0ubuntu0~gpu18.04.1) but 390.129-0ubuntu0~gpu18.04.1 is installed
                   Depends: nvidia-kernel-source-390 (= 390.129-0ubuntu0~gpu18.04.1) but 390.129-0ubuntu0~gpu18.04.1 is installed
                   Depends: libnvidia-compute-390 (= 390.129-0ubuntu0~gpu18.04.1) but 390.129-0ubuntu0~gpu18.04.1 is installed
                   Depends: nvidia-compute-utils-390 (= 390.129-0ubuntu0~gpu18.04.1) but 390.129-0ubuntu0~gpu18.04.1 is installed
                   Depends: libnvidia-decode-390 (= 390.129-0ubuntu0~gpu18.04.1) but 390.129-0ubuntu0~gpu18.04.1 is installed
                   Depends: libnvidia-encode-390 (= 390.129-0ubuntu0~gpu18.04.1) but 390.129-0ubuntu0~gpu18.04.1 is installed
                   Depends: nvidia-utils-390 (= 390.129-0ubuntu0~gpu18.04.1) but 390.129-0ubuntu0~gpu18.04.1 is installed
                   Depends: xserver-xorg-video-nvidia-390 (= 390.129-0ubuntu0~gpu18.04.1) but 390.129-0ubuntu0~gpu18.04.1 is installed
                   Depends: libnvidia-cfg1-390 (= 390.129-0ubuntu0~gpu18.04.1) but 390.129-0ubuntu0~gpu18.04.1 is installed
                   Depends: libnvidia-ifr1-390 (= 390.129-0ubuntu0~gpu18.04.1) but 390.129-0ubuntu0~gpu18.04.1 is installed
                   Depends: libnvidia-fbc1-390 (= 390.129-0ubuntu0~gpu18.04.1) but 390.129-0ubuntu0~gpu18.04.1 is installed
I thought I had purged 390? Please help!
EDIT:
sudo apt-get install -f
Reading package lists... Done
Building dependency tree
Correcting dependencies... Done
The following packages were automatically installed and are no longer required:
  lib32gcc1 libc6-i386 libllvm8 libllvm8:i386
Use 'sudo apt autoremove' to remove them.
The following additional packages will be installed:
  libnvidia-gl-390 libnvidia-gl-390:i386
The following NEW packages will be installed:
0 upgraded, 2 newly installed, 0 to remove and 15 not upgraded.
15 not fully installed or removed.
Need to get 0 B/29.2 MB of archives.
After this operation, 147 MB of additional disk space will be used.
Do you want to continue? [Y/n] y
(Reading database ... 209301 files and directories currently installed.)
Preparing to unpack .../libnvidia-gl-390_390.129-0ubuntu0~gpu18.04.1_amd64.deb ...
diversion of /usr/lib/x86_64-linux-gnu/libGL.so.1 to /usr/lib/x86_64-linux-gnu/libGL.so.1.distrib by nvidia-340
dpkg-divert: error: mismatch on package
  when removing 'diversion of /usr/lib/x86_64-linux-gnu/libGL.so.1 by libnvidia-gl-390'
  found 'diversion of /usr/lib/x86_64-linux-gnu/libGL.so.1 to /usr/lib/x86_64-linux-gnu/libGL.so.1.distrib by nvidia-340'
dpkg: error processing archive /var/cache/apt/archives/libnvidia-gl-390_390.129-0ubuntu0~gpu18.04.1_amd64.deb (--unpack):
 new libnvidia-gl-390:amd64 package pre-installation script subprocess returned error exit status 2
Preparing to unpack .../libnvidia-gl-390_390.129-0ubuntu0~gpu18.04.1_i386.deb ...
diversion of /usr/lib/i386-linux-gnu/libGL.so.1 to /usr/lib/i386-linux-gnu/libGL.so.1.distrib by nvidia-340
  when removing 'diversion of /usr/lib/i386-linux-gnu/libGL.so.1 by libnvidia-gl-390'
  found 'diversion of /usr/lib/i386-linux-gnu/libGL.so.1 to /usr/lib/i386-linux-gnu/libGL.so.1.distrib by nvidia-340'
dpkg: error processing archive /var/cache/apt/archives/libnvidia-gl-390_390.129-0ubuntu0~gpu18.04.1_i386.deb (--unpack):
 new libnvidia-gl-390:i386 package pre-installation script subprocess returned error exit status 2
