Will the upgrade process work all the way from 12.04.1 lts 64 bit to 18.04 lts, or is it better to back up and install 18.04 lts from an iso?
thanks...
user996910
Most folks would suggest backing up and verifying your data (twice, or more) and then wiping the hard drive including 12.04 and installing 18.04. I feel it will be quicker and less troublesome.
A key point is, was your 12.04 install 32-bit or 64-bit? If it was 32-bit, you have no choice but backup-verify, backup-verify, erase, and install anew. Run uname -i to check; if you see x86-64 you have 64-bit. If you see i686 or i386, you have 32-bit.
It may work, if you upgrade
from 12.04 64-bit to 14.04 64-bit, then
from 14.04 64-bit to 16.04 64-bit, then
from 16.04 64-bit to 18.04 64-bit.
Ref: https://askubuntu.com/a/1055003/197910 and https://askubuntu.com/a/47812/197910
K7AAY
  • 17,705
