I have Ubuntu 18.04 system running apache2 and SSL from LetsEncrypt. Also I have connected a domain name to my server. I've tried changing permissions and folder owners, but no matter what I do, I still get the 403 Forbidden error when I try to access my domain(it is auto-redirecting to https btw). Here are the config files (I'm replacing my domain with sample-domain.eu below):
apache2.conf:
DefaultRuntimeDir ${APACHE_RUN_DIR}
PidFile ${APACHE_PID_FILE}
Timeout 300
KeepAlive On
MaxKeepAliveRequests 100
KeepAliveTimeout 5
User ${APACHE_RUN_USER}
Group ${APACHE_RUN_GROUP}
HostnameLookups Off
ErrorLog ${APACHE_LOG_DIR}/error.log
LogLevel warn
IncludeOptional mods-enabled/*.load
IncludeOptional mods-enabled/*.conf
Include ports.conf
<Directory />
        Options FollowSymLinks
        AllowOverride All
        Require all denied
</Directory>
<Directory /usr/share>
        AllowOverride All
        Require all granted
</Directory>
AccessFileName .htaccess
<FilesMatch "^\.ht">
        Require all denied
</FilesMatch>
LogFormat "%v:%p %h %l %u %t \"%r\" %>s %O \"%{Referer}i\" \"%{User-Agent}i\"" vhost_combined
LogFormat "%h %l %u %t \"%r\" %>s %O \"%{Referer}i\" \"%{User-Agent}i\"" combined
LogFormat "%h %l %u %t \"%r\" %>s %O" common
LogFormat "%{Referer}i -> %U" referer
LogFormat "%{User-agent}i" agent
IncludeOptional conf-enabled/*.conf
IncludeOptional sites-enabled/*.conf
Envvars:
unset HOME
if [ "${APACHE_CONFDIR##/etc/apache2-}" != "${APACHE_CONFDIR}" ] ; then
        SUFFIX="-${APACHE_CONFDIR##/etc/apache2-}"
else
        SUFFIX=
fi
export APACHE_RUN_USER=www-data
export APACHE_RUN_GROUP=www-data
export APACHE_PID_FILE=/var/run/apache2$SUFFIX/apache2.pid
export APACHE_RUN_DIR=/var/run/apache2$SUFFIX
export APACHE_LOCK_DIR=/var/lock/apache2$SUFFIX
export APACHE_LOG_DIR=/var/log/apache2$SUFFIX
export LANG=C
export LANG
/sites-enabled/000-default.conf
<VirtualHost *:80>
        ServerAdmin webmaster@sample-domain.eu
        DocumentRoot /var/www/sample-domain.eu/public_html
        CustomLog ${APACHE_LOG_DIR}/access.log combined
</VirtualHost>
/sites-enabled/sample-domain.eu.conf
<VirtualHost *:80>
    ServerName sample-domain.eu
    ServerAlias www.sample-domain.eu
    <Directory /var/www/sample-domain.eu/public_html>
        Options -Indexes +FollowSymLinks
        AllowOverride All
    </Directory>
    ErrorLog ${APACHE_LOG_DIR}/sample-domain.eu-error.log
    CustomLog ${APACHE_LOG_DIR}/sample-domain.eu-access.log combined
RewriteEngine on
RewriteCond %{SERVER_NAME} =sample-domain.eu [OR]
RewriteCond %{SERVER_NAME} =www.sample-domain.eu
RewriteRule ^ https://%{SERVER_NAME}%{REQUEST_URI} [END,NE,R=permanent]
</VirtualHost>
sites-enabled/sample-domain.eu-le-ssl.conf
<IfModule mod_ssl.c>
<VirtualHost *:443>
        AllowOverride All
    </Directory>
Include /etc/letsencrypt/options-ssl-apache.conf
SSLCertificateFile /etc/letsencrypt/live/sample-domain.eu/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/sample-domain.eu/privkey.pem
</VirtualHost>
</IfModule>
Also I have index.html file in /var/www/sample-domain.eu/public_html EDIT: forgot to mention that I have phpmyadmin and webmin installed and both are working with their urls: /phpmyadmin /:10000
niki
  • 101
I have made it work, however I'm not sure if this is secure option to do.
In /etc/apache2/apache2.conf file, I have changed the "Require all denied" to "Require all granted" here:
<Directory />
        AllowOverride All
        Require all granted
</Directory>
I'm not sure why it was set to all denied, since I did not change it. However, the server is now working, and no longer throwing error 403.
nikolay
  • 121
