Currently, I am running Ubuntu 18.04.03 on a 1TB hard drive and I would like to move Ubuntu to my 256 GB SSD for booting. I would like to put some files on the SSD and keep some on the HDD as well. Furthermore, I would like to keep Windows on the HDD. What is the best way of doing this process? (There is nothing on the SSD that I would need to keep.)
EDIT: There is also a copy of windows on the SSD. I would like to copy over Windows to the HDD before I format the SSD.
Below is an image of my disk partitions in Gparted. System Partitions
Here is the output of fdisk -l (the part about partitions).
Disk /dev/sda: 931.5 GiB, 1000204886016 bytes, 1953525168 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disklabel type: gpt
Disk identifier: 20382797-872E-40E8-8700-5D36162941E6
Device Start End Sectors Size Type
/dev/sda1 2048 534527 532480 260M EFI System
/dev/sda2 534528 796671 262144 128M Microsoft reserved
/dev/sda3 796672 964498167 963701496 459.5G Microsoft basic data
/dev/sda4 1887537152 1889585151 2048000 1000M Windows recovery environment
/dev/sda5 1889585152 1952499711 62914560 30G Windows recovery environment
/dev/sda6 1952499712 1953421311 921600 450M Lenovo boot partition
/dev/sda7 964499456 1887537151 923037696 440.1G Linux filesystem
Here is the output of df.
Filesystem 1K-blocks Used Available Use% Mounted on
udev 6099764 0 6099764 0% /dev
tmpfs 1224388 2036 1222352 1% /run
/dev/sda7 453224936 113265440 316867172 27% /
tmpfs 6121936 217288 5904648 4% /dev/shm
tmpfs 5120 4 5116 1% /run/lock
tmpfs 6121936 0 6121936 0% /sys/fs/cgroup
/dev/loop0 1024 1024 0 100% /snap/gnome-logs/73
/dev/loop4 1024 1024 0 100% /snap/gnome-logs/61
/dev/loop1 67584 67584 0 100% /snap/discord/93
/dev/loop5 144128 144128 0 100% /snap/gnome-3-26-1604/92
/dev/loop6 153600 153600 0 100% /snap/gnome-3-28-1804/71
/dev/loop8 150912 150912 0 100% /snap/obs-studio/604
/dev/loop11 36224 36224 0 100% /snap/gtk-common-themes/1198
/dev/loop20 4224 4224 0 100% /snap/gnome-calculator/406
/dev/loop13 3840 3840 0 100% /snap/gnome-system-monitor/95
/dev/loop14 15104 15104 0 100% /snap/gnome-characters/317
/dev/loop9 55808 55808 0 100% /snap/core18/1144
/dev/loop16 144128 144128 0 100% /snap/gnome-3-26-1604/90
/dev/loop19 4352 4352 0 100% /snap/gnome-calculator/501
/dev/loop17 3840 3840 0 100% /snap/gnome-system-monitor/100
/dev/loop18 15104 15104 0 100% /snap/gnome-characters/296
/dev/loop2 153600 153600 0 100% /snap/gnome-3-28-1804/67
/dev/loop7 43904 43904 0 100% /snap/gtk-common-themes/1313
/dev/loop10 55808 55808 0 100% /snap/core18/1098
/dev/loop12 90880 90880 0 100% /snap/core/7396
/dev/loop15 91264 91264 0 100% /snap/core/7713
/dev/loop3 151552 151552 0 100% /snap/obs-studio/525
/dev/sda1 262144 33892 228252 13% /boot/efi
tmpfs 1224384 12 1224372 1% /run/user/124
tmpfs 1224384 28 1224356 1% /run/user/1001
