I'm facing a problem after using
$ sudo systemctl status apache2
apache2.service - The Apache HTTP Server
Loaded: loaded (/lib/systemd/system/apache2.service; enabled; vendor preset: enabled)
Drop-In: /lib/systemd/system/apache2.service.d
└─apache2-systemd.conf
Active: active (running) since Sun 2019-09-15 04:16:20 IST; 10s ago
Process: 7043 ExecStop=/usr/sbin/apachectl stop (code=exited, status=0/SUCCESS)
Process: 7048 ExecStart=/usr/sbin/apachectl start (code=exited, status=0/SUCCESS)
Main PID: 7053 (apache2)
Tasks: 6 (limit: 4559)
CGroup: /system.slice/apache2.service
├─7053 /usr/sbin/apache2 -k start
├─7054 /usr/sbin/apache2 -k start
├─7055 /usr/sbin/apache2 -k start
├─7056 /usr/sbin/apache2 -k start
├─7057 /usr/sbin/apache2 -k start
└─7058 /usr/sbin/apache2 -k start
Sep 15 04:16:20 deb-Inspiron-3542 systemd[1]: Starting The Apache HTTP
Server... Sep 15 04:16:20 deb-Inspiron-3542 apachectl[7048]:
**AH00558: apache2: Could not reliably determine the server's fully qualified domain name, us** Sep 15 04:16:20 deb-Inspiron-3542
systemd[1]: Started The Apache HTTP Server.
What is the better way to overcome that?
Thanks Debajyoti
