After an Ubuntu 16.04 to 18.04 upgrade virtually all calls to apt-get install result in errors of this sort ...
Reading package lists... Done
Building dependency tree
texstudio : Depends: libpoppler-qt5-1 (>= 0.24.5) but it is not going to be installed
Note that I see something similar on every package I try to install.
I have tried the various sudo apt-get -f install, sudo apt-get clean, etc. to no avail. Also I removed all other repositories, and only have official ones left.
So, the big question is have I nuked my system?
