I had Ubuntu 14 and upgraded to 16, but there were some problems during the installation with apt update, upgrade, etc. The computer is working now, but I still have some minor issues, some times depending on what package I try to install.
The thing is, I am supposedly using Ubuntu 16.04 now (that's what "about this computer" says) but if I enter tty1, for example, I get this:
Ubuntu 16.04.6 LTS ......
(login)
Welcome to Ubuntu 18.04.3 LTS ....
Documentation
0 packages can be updated
New release '18.04.2 LTS' available.
Run do-release-upgrade to upgrade it
Which is very confusing. Regarding some problems I have, for example, I get this error when trying to execute an application:
error while loading shared libraries: libmysqlclient.so.18: cannot open shared object file: No such file or directory`
So I use apt-file search and find that I need libmysqlclient-dev, but this is what I get when I try to install the package:
libmysqlclient-dev : Depends: zlib1g-dev but it is not going to be installed
Anything I could try to fix these problems?
