I am looking to install Nvidia's proprietary drivers in order to be able to use CUDA for some Machine Learning.
But I am not able to select the proprietary driver option as the GPU model is not recognized in Software & Updates under the additional drivers tab: It only says Nvidia Corporation: Unknown
But if I lookup the GPU through a lspci command, it is detected correctly: It is indeed a GTX1660
Does someone know why that is the case?
A manual install of the driver, indeed solved the issue. Well the GPU model still isn't recognized but I have a working and compatible driver. Thank you!
