I have searched and read so many questions and blogs including the ArchWiki but failed to find how to reasonably speed up the boot process.
Here is a summary of a few things I've done:
Checked
fstabfile confirming that the UUID is the same as that for/dev/sda3where my filesystem is.Disabled most startup items(including apt updates)
Checked to see if the issues was with my
grubconfig, changednomodesetandquiet splashwhich made my boot time worse.- Read something about blacklisting the tmp_module but had no idea what that was so didn't try.
I have listed only a few things I can remember off of my head.
This is the output I get from systemd:
systemd-analyze blame | head
23.550s dev-sda3.device
21.272s systemd-journal-flush.service
16.297s apport-autoreport.service
15.562s dev-loop21.device
15.413s dev-loop20.device
15.115s dev-loop13.device
15.040s dev-loop12.device
15.039s dev-loop11.device
15.021s dev-loop19.device
14.225s dev-loop14.device
As it can probably be seen, this is unusually slow and I right now am not sure how to best cut these times. If it helps, I'm dual booting from a 1TB external HDD.
Output from critical chain:
The time after the unit is active or started is printed after the "@" character.
The time the unit takes to start is printed after the "+" character.
graphical.target @1min 4.977s
└─multi-user.target @1min 4.975s
└─postfix.service @1min 4.902s +70ms
└─postfix@-.service @55.756s +9.141s
└─network-online.target @55.753s
└─NetworkManager-wait-online.service @49.616s +6.136s
└─NetworkManager.service @41.505s +8.108s
└─dbus.service @38.428s
└─basic.target @38.298s
└─sockets.target @38.295s
└─snapd.socket @38.251s +38ms
└─sysinit.target @37.976s
└─apparmor.service @33.286s +4.689s
└─local-fs.target @33.280s
└─run-user-121.mount @1min 5.982s
└─local-fs-pre.target @12.209s
└─systemd-tmpfiles-setup-dev.service @8.726s +3.47
└─kmod-static-nodes.service @8.359s +362ms
└─systemd-journald.socket @8.355s
└─system.slice @8.304s
How can I best solve this?
Thank you!
