I have many videos in a folder, and I want to compress them all with one command.
To compress one video I use:
sudo apt-get install ffmpeg
ffmpeg -i input.mp4 output.mp4
But what if I have many videos I want to compress? I've tried the following:
ffmpeg -i ./videos ./compressed-videos
But then I get this error:
./videos: Is a directory
I would use bash for loop for this purpose - let's assume you are in the parent directory, that contains the directories videos/ and compressed/:
for f in videos/*mp4; do ffmpeg -i "$f" "compressed/${f##*/}"; done
Or if you want to convert any type of video file to mkv, you can use:
for f in videos/*; do ffmpeg -i "$f" "compressed/$(basename "${f%.*}").mkv"; done
In the above examples:
  • ${var##*/} will outputs all characters after the last slash /, so only the filename without the path will remains;
  • ${f%.*} will outputs all characters before the last dot, so the path and the filename will be kept but the file extension will be removed. Then the command substitution $(basename "/path/name") will outputs only the name without the path.
References:
pa4080
  • 30,621
