26
Every time I reboot I loose the iptables rules that took me so looong to enter. I know I can save them and restore them on boot, but is there anyway to save them forever? Do I really need to restore them on boot every time? Seriously?
The problem is I have a HUGE list of IPs in which I use a while loop to load them in. This can take upwards of 10 minutes.
This is my home FTP server. It's a small vm with 1gb ram and very little processing power. There are so many IPs because I've pretty much given up on the Asian continent. I don't need them to be hitting up my FTP server everyday with brute force. I also block gov. monitors, trackers and spammers.
This is the while loop I use to load in the list.
grep INPUT block.list | while read LISTA; do sudo iptables -A $LISTA; done
capdragon
  • 1,047
apt-get install iptables-persistent
On install, it should save your current iptables config. Otherwise you can save them to these files (depending on v4 or v6) and iptables-persistent will load them on boot :)
iptables-save > /etc/iptables/rules.v4
ip6tables-save > /etc/iptables/rules.v6
Matt Fletcher
  • 463
First, create a file with the contents of iptables-save:
sudo iptables-save > /etc/iptables_rules
It doesn't really matter where you put the file, all you have to do is make sure that the next line refers to the same file. Next, open /etc/rc.local and add this line:
/sbin/iptables-restore < /etc/iptables_rules
From now on, every time your computer powers up or restarts iptables will load rules from the file that you specified.
gertvdijk
  • 69,427
If you do have a lot of rules you should also consider using ipset in conjunction with iptables. Ipset uses an indexed database table and is a lot faster than iptables when looking up an address to decide whether to accept or deny.
http://ipset.netfilter.org/index.html
