I have the following Ubuntu version: 14.04.6 LTS and I'm trying to upgrade to 16.04 with
sudo do-release-upgrade
This command fails reporting:
An unresolvable problem occurred while calculating the upgrade:
E:Unable to correct problems, you have held broken packages.
This can be caused by:
 * Upgrading to a pre-release version of Ubuntu
 * Running the current pre-release version of Ubuntu
 * Unofficial software packages not provided by Ubuntu
And /var/log/dist-upgrade/main.log says:
2019-09-06 17:15:26,873 ERROR Dist-upgrade failed: 'E:Error, pkgProblemResolver:::Resolve generated breaks, this may be caused by held packages
My question is: how to identify and delete these broken deps?
Thank you.
caneta
  • 121
I solved: it was very useful to me this other answer in pointing out where packages were broken during upgrade.
I removed some packages reported here and from time to time re-trying do-release-upgrade util it succeded.
Another useful command to me was dpkg --get-selections | grep deinstall: I've uninstalled everything reported by this command.
caneta
  • 121
