35
When I do
sudo umount /media/KINGSTON
I got
umount: /media/KINGSTON: device is busy.
I close all the windows and make sure all shell are pointing to other directories. How can I find which process is preventing the umount?
5 Answers5
36
open a terminal:
fuser -c /media/KINGSTON
It will output something like this:
/media/KINGSTON/: 3106c 11086
This will give you the pid of the processes using this volume. The extra character at the end of pid will give some extra info. ( c in 3106c)
c - the process is using the file as its current working directory
m - the file is mapped with mmap
o - the process is using it as an open file
r - the file is the root directory of the process
t - the process is accessing the file as a text file
y - this file is the controlling terminal for the process
So to unmount just kill that pids and re-try the unmount
sudo kill -9 3106 11086
Note: To find the exact application name of these pids you may use this command
cat /proc/<pid>/cmdline
For example : cat /proc/11086/cmdline
this will output something like below.
    evince^@/media/KINGSTON/Ubuntu-guide.pdf^@
Hope this will help
aneeshep
  • 30,949
The most useful tool is lsof Install lsof. It shows what files are in used by what processes. If /media/KINGSTON is a mount point (the device name would also work), the following command shows all files that are in use on this mount point:
lsof /media/KINGSTON
If you run this command as an ordinary user, it will only show your own processes¹. Run sudo lsof /media/KINGSTON to see all users' processes.
The output from lsof looks like this:
COMMAND   PID   USER   FD   TYPE DEVICE SIZE/OFF   NODE NAME
zsh4    31421 gilles  cwd    DIR    8,1     4096 130498 /var/tmp
zsh4    31421 gilles  txt    REG    8,1   550804 821292 /bin/zsh4
zsh4    31421 gilles  mem    REG    8,1    55176 821326 /usr/lib/zsh/4.3.10/zsh/complist.so
zsh4    31421 gilles   12r   REG    8,1   175224 822276 /usr/share/zsh/functions/Completion.zwc
The COMMAND column shows the name of the program executable and the PID column shows the process ID. The NAME column shows the file name; you might see (deleted) if the file was deleted while open (when a file is deleted, it no longer has a name, but it still exists until the last process using it closes the file). USER should be self-explanatory. The other columns don't matter here except perhaps FD, which shows how the file is used by the process:
  • cwd: current working directory
  • txt: the program executable²
  • mem: a memory-mapped file (here, think of it as an open file)
  • a number: an actual open file; a subsequent letter indicates the opening mode, such as r for reading and w for writing
There is no mechanical way to locate the window where a file is open (this is in fact not technically meaningful: if a process has several windows, a file is not particularly associated with one window or another), nor even any simple way of identifying a process's window (and of course a process doesn't have to have any windows). But usually the command name and file name are enough to locate the offender and close the file properly.
If you can't close the file and just want to end it all, you can kill the process with kill 31421 (where 31421 is the process ID) or kill -HUP 31421 (“hang up”). If plain killing doesn't do the trick, kill with extreme prejudice: kill -KILL 31421.
There is a GUI for lsof, glsof, but it's not quite ready for prime time yet, and isn't packaged for Ubuntu so far.
¹ Lsof can list some information about other users's processes, but it doesn't detect the mount point so won't list them if you specify a mount point.
² Executable code is often called text in discussions of executable formats.
Zanna
  • 72,312
Meanwhile the fuser command has much improved. You can do the full job with a single command:
$ sudo fuser -ickv /"mountpoint"
Where:
  • parameter k kills the offending process,
  • while v shows in advance the process and its user
  • and i asks you for confirmation.
If some process resists, then try again with fuser -ickv -9 (or more generally with -SIGNAL) that kills the most stubborn ones.
But you will always find some "immortal" process...!
In this cases I lately learned to use
$ sudo umount --lazy --force <mountpoint>
as a last resource, that up to now worked for me every time.
Also this can help:
lsof | grep \/media\/KINGSTON
muru
  • 207,228
Note! One other thing that keeps a mountpoint busy is a submount, which isn't a process so won't show up if you search via lsof or fuser. And yes, it should be obvious,but in this age of a long list of mounts due to docker and rebinds and etc, it can be easy to overlook that, for instance:
# mount | wc -l
39
# mount |grep usb
/dev/sde1 on /media/usb type vfat (rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=utf8,shortname=mixed,errors=remount-ro)
/media/usb/boot/modloop-lts on /.modloop type squashfs (ro,relatime)
/media/usb cannot be unmounted because of the second mount. (example taken from a real-life alpine linux "diskless" system where I just spent around 10min trying to figure out why I couldn't unmount /media/usb)
pjz
  • 274
