I've used gnucash successfully until some years ago and would like to start using it again. I installed it from the standard Ubuntu packets. Now what works is: Modify account tree, including renaming accounts and adding new ones. What doesn't: Enter a transaction. I can place the cursor in an entry field for a transaction, but as soon as I only press the Shift Key or any letter key to enter anything in that field, gnucash crashes without any trace that I can see. Started from a terminal, it leaves the message:
Speicherzugriffsfehler (Speicherabzug geschrieben)
in English:
Memory access error (memory dumped)
My system is this:
Xubuntu 19.04
Intel Core i5-7400 CPU @ 3 GHz 8 GB RAM
Graphics 3840 x 2160 Pixel
MESA DRI Intel HD Graphics 630 (Kaby Lake GT2)
The X.Org Foundation
Gnucash
Version: 3.4
Build ID: 3.4+ (2018-12-30)
Finance::Quote: 1.47
On two older laptop computers in our household, under the same OS, gnucash works as expected.
What can I do to narrow down where things go wrong?
Here are free -h and sudo lshw -C memory:
thomas@Schleiereule:~$ free -h
          Gesamt   belegt    frei        gemns. Puffer/Cache verfügbar
Speicher:       7,7Gi       4,7Gi       1,4Gi       1,1Gi       1,5Gi       1,6Gi
Auslagerungsspeicher:        14Gi       5,5Gi       9,4Gi
thomas@Schleiereule:~$ sudo lshw -C memory
  *-firmware
       Beschreibung: BIOS
       Hersteller: American Megatrends Inc.
       Physische ID: 0
       Version: 1.70
       date: 05/08/2017
       Größe: 64KiB
       Kapazität: 15MiB
       Fähigkeiten: pci upgrade shadowing cdboot bootselect socketedrom edd int13floppy1200 int13floppy720 int13floppy2880 int5printscreen int9keyboard int14serial int17printer acpi usb biosbootspecification uefi
  *-memory
       Beschreibung: Systemspeicher
       Physische ID: 3c
       Steckplatz: Systemplatine oder Hauptplatine
       Größe: 8GiB
     *-bank:0
          Beschreibung: DIMM DDR4 Synchron 2400 MHz (0,4 ns)
          Produkt: CT8G4DFD824A.C16FBD1
          Hersteller: 859B
          Physische ID: 0
          Seriennummer: 1517B96C
          Steckplatz: ChannelA-DIMM0
          Größe: 8GiB
          Breite: 64 bits
          Takt: 2400MHz (0.4ns)
     *-bank:1
          Beschreibung: Project-Id-Version: lshwReport-Msgid-Bugs-To: FULL NAME <EMAIL@ADDRESS>PO-Revision-Date: 2012-05-30 08:16+0000Last-Translator: Hendrik Knackstedt <Unknown>Language-Team: German <de@li.org>MIME-Version: 1.0Content-Type: text/plain; charset=UTF-8Content-Transfer-Encoding: 8bitX-Launchpad-Export-Date: 2019-04-12 08:46+0000X-Generator: Launchpad (build 18920)Project-Id-Version: lshwReport-Msgid-Bugs-To: FULL NAME <EMAIL@ADDRESS>PO-Revision-Date: 2012-05-30 08:16+0000Last-Translator: Hendrik Knackstedt <Unknown>Language-Team: German <de@li.org>MIME-Version: 1.0Content-Type: text/plain; charset=UTF-8Content-Transfer-Encoding: 8bitX-Launchpad-Export-Date: 2019-04-12 08:46+0000X-Generator: Launchpad (build 18920) [leer]
          Physische ID: 1
          Steckplatz: ChannelA-DIMM1
     *-bank:2
          Physische ID: 2
          Steckplatz: ChannelB-DIMM0
     *-bank:3
          Physische ID: 3
          Steckplatz: ChannelB-DIMM1
  *-cache:0
       Beschreibung: L1 Cache
       Physische ID: 42
       Steckplatz: L1 Cache
       Größe: 256KiB
       Kapazität: 256KiB
       Fähigkeiten: synchronous internal write-back unified
       Konfiguration: level=1
  *-cache:1
       Beschreibung: L2 Cache
       Physische ID: 43
       Steckplatz: L2 Cache
       Größe: 1MiB
       Kapazität: 1MiB
       Konfiguration: level=2
  *-cache:2
       Beschreibung: L3 Cache
       Physische ID: 44
       Steckplatz: L3 Cache
       Größe: 6MiB
       Kapazität: 6MiB
       Konfiguration: level=3
  *-memory UNGEFORDERT
       Beschreibung: Memory controller
       Produkt: 100 Series/C230 Series Chipset Family Power Management Controller
       Hersteller: Intel Corporation
       Physische ID: 1f.2
       Bus-Informationen: pci@0000:00:1f.2
       Version: 31
       Breite: 32 bits
       Takt: 33MHz (30.3ns)
       Fähigkeiten: bus_master
       Konfiguration: latency=0
       Ressourcen: memory:df124000-df127fff
Blackface
  • 131
