Since upgrading from ubuntu 16.04 (kernel 4.15.0-60-generic) to 18.04 (kernel 5.0.0-27-generic) v4l now returns multiple /dev/video devices per physical device. This causes issues when trying to map video devices to aliases using udev rules. One of the /dev/video devices can stream video, the other cannot. The udev alias I've created does not seem to consistently choose the correct /dev/video index (the one with streaming capabilities).
I know this post is very similar to this:
Four /dev/video entries but just one camera
However, the accepted answer (bug with skype) does not adequately address the udev issue I'm experiencing.
I see someone has a similar question on stack exchange:
https://unix.stackexchange.com/questions/512759/multiple-dev-video-for-one-physical-device
However, no answer has been accepted.
Additional Information:
Computer make/model: Asus ROG GL503V
Webcam make/model: Genius WideCam F100, Logitech C920, and more.
v4l2-ctl --list-devices
returns:
USB2.0 PC CAMERA: USB2.0 PC CAM (usb-0000:00:14.0-11):
/dev/video4
/dev/video5
USB_Camera: USB_Camera (usb-0000:00:14.0-3):
/dev/video0
/dev/video1
HD Pro Webcam C920 (usb-0000:00:14.0-4.1):
/dev/video6
/dev/video7
USB2.0 HD UVC WebCam: USB2.0 HD (usb-0000:00:14.0-7):
/dev/video2
/dev/video3
Here's a detailed look at the Genius WideCam F100:
user@AsusROG:~$ sudo v4l2-ctl --list-devices
/dev/video0
/dev/video1
/dev/video2
/dev/video3
user@AsusROG:~$ sudo v4l2-ctl --device=/dev/video0 --all
Driver Info (not using libv4l2):
Driver name : uvcvideo
Card type : USB_Camera: USB_Camera
Bus info : usb-0000:00:14.0-3
Driver version: 5.0.21
Capabilities : 0x84A00001
Video Capture
Metadata Capture
Streaming
Extended Pix Format
Device Capabilities
Device Caps : 0x04200001
Video Capture
Streaming
Extended Pix Format
Priority: 2
Video input : 0 (Camera 1: ok)
Format Video Capture:
Width/Height : 640/480
Pixel Format : 'YUYV'
Field : None
Bytes per Line : 1280
Size Image : 614400
Colorspace : sRGB
Transfer Function : Default (maps to sRGB)
YCbCr/HSV Encoding: Default (maps to ITU-R 601)
Quantization : Default (maps to Limited Range)
Flags :
Crop Capability Video Capture:
Bounds : Left 0, Top 0, Width 640, Height 480
Default : Left 0, Top 0, Width 640, Height 480
Pixel Aspect: 1/1
Selection: crop_default, Left 0, Top 0, Width 640, Height 480
Selection: crop_bounds, Left 0, Top 0, Width 640, Height 480
Streaming Parameters Video Capture:
Capabilities : timeperframe
Frames per second: 30.000 (30/1)
Read buffers : 0
brightness 0x00980900 (int) : min=-64 max=64 step=1 default=0 value=0
contrast 0x00980901 (int) : min=0 max=95 step=1 default=32 value=32
saturation 0x00980902 (int) : min=0 max=100 step=1 default=55 value=55
hue 0x00980903 (int) : min=-2000 max=2000 step=1 default=0 value=0
white_balance_temperature_auto 0x0098090c (bool) : default=1 value=1
gamma 0x00980910 (int) : min=100 max=300 step=1 default=165 value=165
power_line_frequency 0x00980918 (menu) : min=0 max=2 default=1 value=1
white_balance_temperature 0x0098091a (int) : min=2800 max=6500 step=10 default=4600 value=4600 flags=inactive
sharpness 0x0098091b (int) : min=1 max=7 step=1 default=2 value=2
backlight_compensation 0x0098091c (int) : min=0 max=1 step=1 default=0 value=0
exposure_auto 0x009a0901 (menu) : min=0 max=3 default=3 value=3
exposure_absolute 0x009a0902 (int) : min=50 max=10000 step=1 default=166 value=166 flags=inactive
user@AsusROG:~$ sudo v4l2-ctl --device=/dev/video1 --all
Video Capture
Metadata Capture
Streaming
Extended Pix Format
Device Capabilities
Device Caps : 0x04A00000
Metadata Capture
Streaming
Extended Pix Format
Priority: 2
Here's the versions of various v4l packages I have installed:
ii libv4l-0:amd64 1.14.2-1 amd64 Collection of video4linux support libraries
ii libv4l-dev:amd64 1.14.2-1 amd64 Collection of video4linux support libraries (development files)
ii libv4l2rds0:amd64 1.14.2-1 amd64 Video4Linux Radio Data System (RDS) decoding library
ii libv4lconvert0:amd64 1.14.2-1 amd64 Video4linux frame format conversion library
ii v4l-utils 1.14.2-1 amd64 Collection of command line video4linux utilities
here's an excerpt from lsusb:
Bus 001 Device 017: ID 0458:708c KYE Systems Corp. (Mouse Systems) Genius WideCam F100
and the associated udev rule:
KERNEL=="video?", SUBSYSTEM=="video4linux", ATTRS{idVendor}=="0458", ATTRS{index}=="0", ATTRS{idProduct}=="708c", SYMLINK+="v4l/hd_cam"
Any input would be greatly appreciated
