I am trying to install CARLA on ubuntu 19.04, but it requires clang-7 package. I tried to install clang-7 with
sudo apt install clang-7
But I got the error:
Reading package lists... Done
Building dependency tree
clang-7 : Depends: libstdc++-5-dev but it is not installable
Depends: libgcc-5-dev but it is not installable
Depends: libobjc-5-dev but it is not installable
Recommends: llvm-7-dev but it is not going to be installed
Recommends: libomp-7-dev but it is not going to be installed
I tried correcting broken packages by referring to solution_1 and solution_2, but did not solve the issue.
Finally I installed aptitude by referring to this answer, and tried to install clang by:
sudo aptitude install clang-7
But got the the following output:
The following NEW packages will be installed:
clang-7{b} libclang-common-7-dev{a} libclang1-7{a} libomp-7-dev{ab} libomp5-7{ab} llvm-7{a} llvm-7-dev{a} llvm-7-runtime{a}
0 packages upgraded, 8 newly installed, 0 to remove and 0 not upgraded.
Need to get 45,3 MB of archives. After unpacking 303 MB will be used.
libomp-7-dev : Conflicts: libomp-x.y-dev which is a virtual package, provided by:
- libomp-7-dev (1:7.1.0~svn353565-1~exp1~20190408084827.60), but 1:7.1.0~svn353565-1~exp1~20190408084827.60 is to be installed
- libomp-8-dev (1:8-3), but 1:8-3 is installed
- libomp-7-dev (1:7.0.1-8), but 1:7.1.0~svn353565-1~exp1~20190408084827.60 is to be installed
clang-7 : Depends: libstdc++-5-dev which is a virtual package and is not provided by any available package
Depends: libgcc-5-dev which is a virtual package and is not provided by any available package
Depends: libobjc-5-dev which is a virtual package and is not provided by any available package
libomp5-7 : Conflicts: libomp-x.y which is a virtual package, provided by:
- libomp5-7 (1:7.1.0~svn353565-1~exp1~20190408084827.60), but 1:7.1.0~svn353565-1~exp1~20190408084827.60 is to be installed
- libomp5-8 (1:8-3), but 1:8-3 is installed
- libomp5-7 (1:7.0.1-8), but 1:7.1.0~svn353565-1~exp1~20190408084827.60 is to be installed
libomp5-8 : Conflicts: libomp-x.y which is a virtual package, provided by:
libomp-8-dev : Conflicts: libomp-x.y-dev which is a virtual package, provided by:
The following actions will resolve these dependencies:
Keep the following packages at their current version:
1) clang-7 [Not Installed]
2) libomp-7-dev [Not Installed]
3) libomp5-7 [Not Installed]
Accept this solution? [Y/n/q/?]
No packages will be installed, upgraded, or removed.
0 packages upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 0 B of archives. After unpacking 0 B will be used.
Please guide me to install clang-7 on Ubuntu 19.04 and help me.
