I'm a beginner with Ubuntu, trying to understand how package management works, and I have a few questions. This has occurred whilst I have been trying to install CUDA on my machine, so I will use CUDA as an example, but I am keen to learn about this in general terms.
So, following a tutorial, I have downloaded a file called cuda-repo-ubuntu1804_10.0.130-1_amd64.deb. Then I have run sudo dpkg -i cuda-repo-ubuntu1804_10.0.130-1_amd64.deb. Finally, I have run sudo apt install cuda.
My first question is: What is the difference between running dpkg -i on a .deb file, and running apt install on a package name? From what I have read, apt uses dpkg underneath, so I am confused as to why both would be used in this case.
My second question is: What is telling my apt the meaning of cuda? I understand how running dpkg on a local file will then install this file, but I don't understand how the name cuda is linked with this .deb file.
My third question is: Let's say there is a newer version of this package, which comes in a file called cuda-repo-ubuntu1804_10.1_amd64.deb. What would happen if I were to run sudo apt upgrade cuda? Would this remove all files for cuda-repo-ubuntu1804_10.0.130-1_amd64.deb and install cuda-repo-ubuntu1804_10.1_amd64.deb?
Thank you.
Karnivaurus
  • 1,024
dpkg -i <deb_file> installs a locally stored package.
apt install cuda downloads and installs cuda package from Ubuntu repositories and PPAs if any are installed.
If you run sudo apt upgrade, it will check the repositories for new versions of installed packages and upgrade them.
It looks like the cuda-repo-ubuntu1804_10.0.130-1_amd64.deb sets a repository that will be checked for upgrades. You can look into /etc/apt/sources.list.d and see if there is a cuda repository file.
So if you run apt upgrade and there is a new version in that repository, it will get an upgrade.
The cuda name is taken from that repository.
Pilot6
  • 92,041
dpkg can be used exclusively on local files, while apt-get and more recently apt are tools designed to be used by the end user, and can be used both on local files and on repository based files. They are built on top of dpkg, meaning that they will still call it and use it to install whatever. They are, arguably, more user friendly. There shouldn't be any difference in calling apt or dpkg on a local .deb file. But only apt and apt-get can be used on remote files, meaning that they will automatically download and install them. I'm not sure, but apt might also take care of dependencies with local .deb files. It certainly does with repository based packages.
What is telling apt the meaning of cuda are your source files. From what I can tell, cuda are not in the default repositories, probably because it is proprietary software. So, if you try sudo apt install cuda out of the box it won't work, because it will look for it and won't find anything with this name.
What happens is that some programs, as part of their .deb installation file, add themselves to the sources list. Google chrome does something similar. When you download the google chrome .deb file (and your cuda program) they will, as part of their installation add a line to /etc/apt/sources.list or a file to /etc/apt/sources.list.d/, so whenever you run sudo apt update it will go to the link and download a source from them, and on this source there will be a mention of a package called cuda that you can install and be automatically upgraded as sudo apt upgrade. It is similar to adding a PPA. Some other programs add themselves to the sources as part of a bash installation script or they might ask you to add them manually. I believe the best reason to do this is ease of updating, as it will be automated as part of your regular updates.
You should probably ask around the cuda forums for a more authoritative answer on this, and what is the proper process for updating to newer versions. Using the Google Chrome example, it will automatically update to the newer version, so it will remove the old one and keep only the new one. But this is very specific to this cuda package, and how they decided to handle things.
Maybe they use the cuda package that they add to the sources solely for dependencies and free software that they can't bundle with their proprietary package, so you would still need to download a new .deb file and install it. Maybe they use it to update everything, and it will automatically download and install the new version when you run the routinely sudo apt update && sudo apt upgrade. Again, very specific to this package, and you should ask on their support channels.
Podesta
  • 1,146
