I followed this answer: how to configure 2 network interfaces with different gateways
No errors when setting up.
ifconfig:
eno1: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.178.22 netmask 255.255.255.0 broadcast 192.168.178.255
inet6 fe80::21d:9ff:fe6b:ca86 prefixlen 64 scopeid 0x20<link>
ether 00:1d:09:6b:ca:86 txqueuelen 1000 (Ethernet)
RX packets 2785 bytes 224135 (218.8 KiB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 977 bytes 116595 (113.8 KiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
eno2: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.1.37 netmask 255.255.255.0 broadcast 192.168.1.255
inet6 fe80::21d:9ff:fe6b:ca88 prefixlen 64 scopeid 0x20<link>
ether 00:1d:09:6b:ca:88 txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
TX packets 0 bytes 0 (0.0 B)
network interfaces:
# This file describes the network interfaces available on your system
# and how to activate them. For more information, see interfaces(5).
source /etc/network/interfaces.d/*
# The loopback network interface
auto lo
iface lo inet loopback
# The primary network interface
allow-hotplug eno1
iface eno1 inet static
address 192.168.178.22
gateway 192.168.178.1
allow-hotplug eno2
iface eno2 inet static
address 192.168.1.37
post-up ip route add 192.168.1.0/24 dev eno2 src 192.168.1.37 table rt2
post-up ip route add default via 192.168.1.37 dev eno2 table rt2
post-up ip rule add from 192.168.1.37/32 table rt2
post-up ip rule add to 192.168.1.37/32 table rt2
rt_tables:
# reserved values
255 local
254 main
253 default
0 unspec
# local
#1 inr.ruhep
1 rt2
ping -I eno1... ok ping -I eno2... 100% packet loss. I can ping another computer and back to server from that computer. Also I can ping modem. Any external ping like google doesn't work.
Does anyone know what I did wrong? Thank you.
