I've got (what I think) is a rather simple question for backing up an ubuntu-desktop.
There are many posts about this and I see a number of references to software that's no longer in development, etc... So, I thought I'd post here for any up to date smart tips and tricks the community use since it seems I'm looking for more from my backup plan.
My experience so far...
I've used timeshift for the last several months and restored my system successfully from local copies perfectly countless times. It's been absolutely amazing, but I'm not happy with a few areas and looking for ways to do a bit more
My list of issues:
  1. Being forced to use the root of any partition I give it - Not being able to back up to two different locations (I'd like at least one additional copy sent to a USB drive that I can run with a command as and when necessary)
  2. A limitation of a single backup location - can't have a local and USB drive copy
  3. Limited command line ability
Ideally, I'd like to find a decent single application alternative that can do the following:
  1. Full live system backups with monthly and incremental snapshots (as timeshift does)
  2. File and folder backups such as Deja Dupe (Something with nautilus integration as Deja Dupe would be pretty amazing)
  3. Most importantly - Ability to use the command line to backup to an alternative offsite location - i.e. a USB drive
I could, of course, use timeshift for live backups and Deja dupe for the file and folder bit if options are really limited - in which case then I'd need a decent and low resource usage command line solution for piping live systems backups and snapshots to a folder on a USB hard drive.
Any good suggestions please people?
I'd also be interested in hearing about what you do to secure the system and your files on your system. Perhaps what I am asking for is either too much or misguided in some way.
Thank you
UPDATE: I guess if I had setup the drives with LVM this would be a far easier question to answer.
