Neither iwconfig nor iwlist seem to be able to do this for me.
- 7,292
- 2,473
iwgetid provides the ssid
iwgetid -r gives just the name.
In a Bash script try something like myssid=$(iwgetid -r) to put it in a variable
- 713
- 7
- 17
- 1,741
Run nm-tool | grep \*. That should show just the line with the SSID you are connected to.
Edit: The nm-tool utility had ceased to exist, so in 16.04 and newer releases, please use any of the methods suggested by my esteemed colleagues below.
For example: nmcli -t -f active,ssid dev wifi | egrep '^yes' | cut -d\' -f2 works well.
- 33,013
Although the question has already been answered, the iwconfig tool does display the ESSID of the currently connected Wifi network. Perhaps it does not work with connections managed through NetworkManager but it works with interfaces managed through ifup/ifdown:
iwconfig | grep wlan0
lists:
wlan0 IEEE 802.11bgn ESSID:"ahoi"
- 3,151
None of the prior answers worked for me unfortunately. I was however able to get the details via
$ sudo iw dev wlan0 info
and got
Interface wlan0
ifindex 5
wdev 0x1
addr **:**:*:*:*:*
ssid *****
type AP
wiphy 0
channel 2 (2417 MHz), width: 20 MHz, center1: 2417 MHz
- 311
- 2
- 3
nmcli -t -f name connection show --active
shows the same output without listing all available SSIDs in vicinity so without delay. if more network interfaces are available and active can be parsed by interface name like so:
nmcli -t -f name,device connection show --active | grep wlp3s0 | cut -d\: -f1
- 91
- 1
- 1
You can also use the iw tool (from the iw package) to obtain the WiFi link parameters which includes the currently associated SSID - e.g for wlan0:
iw dev wlan0 link
- 3,391
simply use this command to get only the ssid "NAME"
iw dev wlan0 info | grep ssid | awk '{print $2}'
Where wlan0 is the interface for your Wi-Fi card. Check it in ifconfig or iwconfig.
The output is only the "ssid name" of the network you connected...
- 151
