A year or so ago I installed 18.04 Now I've installed 18.04.3 18.04.2 and finally 18.04 to an other hard disk on the same PC and the kernel is always 5.0.0-27-generic, how can I get back the 4.xxx that originally came with 18.04 (and 18.04.1 and 18.04.2, according to google wisdom 5.xxx was introduced with 18.04.3).
I've got a third party closed source library that fails to install on kernel 5 and I've traced the problem to a changed header file in that comes with the kernel. (Linux 5.0: macro "access_ok" passed 3 arguments, but takes just 2).
nyholku
  • 133
It is quite easy. Run in a terminal:
sudo apt install linux-generic
That will install the 4.15 kernel and related meta packages.
Then boot with that kernel using grub menu and remove all 5.0 kernel packages.
Pilot6
  • 92,041
