How can I install the new virtual machine app Boxes (https://live.gnome.org/Boxes) in Ubuntu?
Asked
Active
Viewed 2.4k times
11
Gnome-boxes cannot be installed on 12.04.
GNOME boxes has not been packaged due to dependency problems. If you want to try out the boxes, try compiling from the source.
For 12.10 and newer it can be installed by simply typing:
sudo apt-get install gnome-boxes
If you are looking to use a newer version, you can consider installing it from the source tarballs.
Do take note that GNOME boxes is still very much in development.
First install gnome-boxes and the required dependencies libvirt-bin and qemu-kvm
sudo apt install libvirt-bin qemu-kvm gnome-boxes
Then add yourself to the kvm group
sudo usermod -aG kvm $USER
Then allow kvm group to run commands and edit the qemu.conf file
sudo sed -i -e 's/\#group\ =\ "root"/group=kvm/g' /etc/libvirt/qemu.conf
Weezy
- 481
Install using Flatpak
sudo apt install flatpak
sudo add-apt-repository ppa:alexlarsson/flatpak
sudo apt update
Now use the following command to install GNOME Boxes
flatpak install flathub org.gnome.Boxes
Or use .flatpakref file to install
NILESH KUMAR P.HD
- 111
- 2
