This bash script will add up vnstat totals for multiple interfaces:
#!/bin/bash
# NAME: vnall
# DESC: Add up multiple interfaces of vnstat into totals for today,
#       yesterday, current week and current month.
# PARM: "today", "yesterday", "week" (current), "month" (current)
# DATE: September 2, 2019. Modified September 4, 2019.
# To discover interfaces `lshw -c network` then place names below
# aInterfaces=( "enp59s0" "wlp60s0" )
# Use automatic discovery if you are unsure of names or don't want to look up
Interfaces=( $(lshw -c network 2>/dev/null | grep name: | cut -d':' -f2) )
Tally () {
    Ktot=0     # Totals in KiB, MiB and GiB
    Mtot=0
    Gtot=0
    # Tally all interfaces
    local i Interface Line Raw ThisNum
    for (( i=0; i<${#aInterfaces[@]}; i++ )) ; do
        Interface="${aInterfaces[i]}"
        if [[ "$vnstatParm" == "" ]] ; then
            Line=$(vnstat -i "$Interface" | grep "$GrepString")
        else
            Line=$(vnstat -i "$Interface" "$vnstatParm" | grep "$GrepString")
        fi
        [[ $Line == "" ]] && continue   # No data collected yet
        if [[ $vnstatParm == "" ]] ; then
            Raw=$(echo "$Line" | awk '{print $8 substr ($9, 1, 1)}')
        else
            Raw=$(echo "$Line" | awk '{print $9 substr ($10, 1, 1)}')
        fi
        ThisNum="${Raw::-1}"    # Number without suffix
        case ${Raw: -1} in      # Decide on last character K, M or G
            K)
                Ktot=$(echo "$Ktot + $ThisNum " | bc) ;;
            M)
                Mtot=$(echo "$Mtot + $ThisNum " | bc) ;;
            G)
                Gtot=$(echo "$Gtot + $ThisNum " | bc) ;;
                echo "Unknown Unit: ${Raw: -1}" ;;
        esac
    done
    [[ $Gtot != "0" ]] && { echo "$Gtot G" ; return ; }
    [[ $Mtot != "0" ]] && { echo "$Mtot M" ; return ; }
    [[ $Ktot != "0" ]] && { echo "$Ktot K" ; return ; }
    echo "N/A"
} # Tally
Init () {
    GrepString="$1"     # Create defaults for "today" and "yesterday"
    vnstatParm=""
    if [[ $1 == week ]] ; then
        GrepString="current $GrepString"
        vnstatParm="-w"
    fi
    if [[ $1 == month ]] ; then
        GrepString=$(date +"%b '%y")
        vnstatParm="-m"
    fi
} # Init
Init "$@"
Tally
Automatic vs Manual interface names
Notes this section of code:
The fourth line automatically discovers the interface names (in my case enp59s0 and wlp60s0) and builds the array of interfaces (aInterfaces). If you prefer to manually specify the names in your script then place a comment (#) at the beginning of the line and uncomment the second line by removing the # line prefix.
Conky code shrinks considerably
Because the new vnall script automatically creates parameters as needed, the conky code is a lot smaller than before:
${color}${goto 5}Today ${goto 100}Yesterday ${goto 225}Week ${goto 325}Month ${color green}
# vnstatd updates database every five minutes
${execi 300 vnall "today"} ${goto 110}${execi 300 vnall "yesterday"} ${goto 220}${execi 300 vnall "week"} ${goto 315}${execi 300 vnall "month"}
Conky Image
