I am running Windows 7, Ubuntu 18.04, Ubuntu 19.04 in a dual *actually three) boot setup. Why is not important.
I am using an HP pavilion dv7 laptop.
First thing, everything works just fine.
Now my issue is this. When ever Ubuntu (i.e. 18.04) does a kernel update, you need to reboot. OK, so I reboot, when I get to the GRUB menu, it does not reflect the addition or change in the kernel version for 18.04. So I have to boot into the other Ubuntu (i.e. 19,04), run GRUB Customizer, then reboot back into Ubuntu 18.04, then when you get to the GRUB menu, it reflects the change in the kernel). The reverse order in Ubuntu does the same thing, so it is not a specific issue from 18.04 to 19.04. It does it both ways.
You area able to boot into either 18.04 or 19.04 without any problem, it just that the update will not show up in the GRUB menu.
Now this is just an irritation for me, not a problem as far as I can see. But why is it happening, am I doing something wrong? Thanks for any suggestions.
user18432
  • 1,167
No, you're doing nothing wrong, that's the way it works.
The boot-loader will read it's configuration-file (/boot/grub/grub.cfg) from the system which installed the boot-loader, this is, following your example 19.04 at the moment. So if you have a new configuration-file in 18.04, the boot-loader will not read that file, it reads the one from 19.04.
You're doing the right thing, you have to boot into 19.04 and update grub's configuration there, that's the hassle with multiple boot systems and there is no way around that.
Sometimes a system-upgrade installs a new version of grub and then also reinstalls the boot-loader. Following your example, at the moment you use the boot-loader from 19.04. You upgrade 18.04 and during the upgrade a new version of grub is installed. From that moment on you will use the boot-loader from 18.04.
Remember: The system which installed grub most recently is the system from which the boot-loader will read it's configuration-file.
mook765
  • 18,644
