Using an HP 245 G6 laptop with AMD A9 APU and Realtek 8723de wireless running Ubuntu 19.04.
To resolve an issue with the laptop being unable to resume from suspend properly (AMDGPU crashing on resume) I've manually installed Linux kernel 5.3 (rc6 currently - I found some info on the issue I was having here https://bugzilla.redhat.com/show_bug.cgi?id=1704792).
However I can't install the driver for the Wi-Fi from https://github.com/lwfinger/rtlwifi_new.git on kernel 5.3 - any ideas on how to get this working in the newer kernel would be appreciated.
Specifically, during the rtlwifi install, after running:
sudo dkms install rtlwifi-new/0.6
I get:
Kernel preparation unnecessary for this kernel. Skipping...
Building module:
cleaning build area....
make -j4 KERNELRELEASE=5.3.0-050300rc6-generic -C /lib/modules/5.3.0-050300rc6-generic/build M=/var/lib/dkms/rtlwifi-new/0.6/build.............(bad exit status: 2)
ERROR (dkms apport): binary package for rtlwifi-new: 0.6 not found
Error! Bad return status for module build on kernel: 5.3.0-050300rc6-generic (x86_64)
Consult /var/lib/dkms/rtlwifi-new/0.6/build/make.log for more information.
The log at /var/lib/dkms/rtlwifi-new/0.6/build/make.log contains:
DKMS make.log for rtlwifi-new-0.6 for kernel 5.3.0-050300rc6-generic (x86_64)
Mon Sep 2 14:42:59 NZST 2019
make: Entering directory '/usr/src/linux-headers-5.3.0-050300rc6-generic'
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/btcoexist/halbtc8192e2ant.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8188ee/dm.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/halmac/halmac_api.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/phydm/phydm_debug.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/halmac/halmac_88xx/halmac_api_88xx_usb.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8188ee/fw.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/btcoexist/halbtc8723b1ant.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/halmac/halmac_88xx/halmac_api_88xx_sdio.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/phydm/phydm_antdiv.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8188ee/hw.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/phydm/phydm_soml.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/halmac/halmac_88xx/halmac_api_88xx.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/btcoexist/halbtc8723b2ant.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/phydm/phydm_smt_ant.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8188ee/led.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/phydm/phydm_interface.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/btcoexist/halbtc8821a1ant.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/halmac/halmac_88xx/halmac_api_88xx_pcie.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8188ee/phy.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/phydm/phydm_phystatus.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/halmac/halmac_88xx/halmac_func_88xx.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/btcoexist/halbtc8821a2ant.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/phydm/phydm_hwconfig.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8188ee/pwrseq.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/phydm/phydm.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/btcoexist/halbtc8822b1ant.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/halmac/halmac_88xx/halmac_8822b/halmac_api_8822b_pcie.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8188ee/rf.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8188ee/sw.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/halmac/halmac_88xx/halmac_8822b/halmac_func_8822b.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/phydm/phydm_dig.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/btcoexist/halbtc8822b2ant.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8188ee/table.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/halmac/halmac_88xx/halmac_8822b/halmac_api_8822b_sdio.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8188ee/trx.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/phydm/phydm_pathdiv.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/halmac/halmac_88xx/halmac_8822b/halmac_api_8822b.o
LD [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8188ee/rtl8188ee.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/phydm/phydm_rainfo.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8192c/main.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/halmac/halmac_88xx/halmac_8822b/halmac_8822b_phy.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/btcoexist/halbtc8822bwifionly.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8192c/dm_common.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/phydm/phydm_dynamictxpower.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/halmac/halmac_88xx/halmac_8822b/halmac_8822b_pwr_seq.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/btcoexist/halbtc8723d1ant.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/phydm/phydm_adaptivity.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8192c/fw_common.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/halmac/halmac_88xx/halmac_8822b/halmac_api_8822b_usb.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/halmac/rtl_halmac.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/btcoexist/halbtc8723d2ant.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/phydm/phydm_cfotracking.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8192c/phy_common.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/phydm/phydm_noisemonitor.o
LD [M] /var/lib/dkms/rtlwifi-new/0.6/build/halmac/halmac.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8192ce/dm.o
LD [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8192c/rtl8192c-common.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8192cu/dm.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/phydm/phydm_dfs.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8192ce/hw.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/btcoexist/halbtcoutsrc.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8192cu/hw.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/phydm/phydm_adc_sampling.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/btcoexist/rtl_btc.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8192ce/led.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/phydm/phydm_ccx.o
LD [M] /var/lib/dkms/rtlwifi-new/0.6/build/btcoexist/btcoexist.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8192de/dm.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8192ce/phy.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8192cu/led.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/phydm/phydm_psd.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8192cu/mac.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8192ce/rf.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8192de/fw.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/phydm/phydm_primary_cca.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8192ce/sw.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8192cu/phy.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8192de/hw.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/phydm/phydm_cck_pd.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8192ce/table.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8192ce/trx.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8192cu/rf.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/phydm/phydm_rssi_monitor.o
LD [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8192ce/rtl8192ce.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8192ee/dm.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8192de/led.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8192cu/sw.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/phydm/phydm_auto_dbg.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8192de/phy.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8192cu/table.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/phydm/phydm_math_lib.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8192cu/trx.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8192ee/fw.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/phydm/phydm_api.o
LD [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8192cu/rtl8192cu.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8192se/dm.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8192ee/hw.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/phydm/phydm_pow_train.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8192se/fw.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8192de/rf.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/phydm/halrf/halrf.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8192se/hw.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8192ee/led.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8192de/sw.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8192ee/phy.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8192de/table.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/phydm/halrf/halphyrf_ce.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8192de/trx.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8192se/led.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/phydm/halrf/halrf_powertracking_ce.o
LD [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8192de/rtl8192de.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8723ae/dm.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8192se/phy.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8192ee/pwrseq.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/phydm/halrf/halrf_powertracking.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8723ae/fw.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8192ee/rf.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/phydm/halrf/halrf_kfree.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8192se/rf.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8723ae/hal_btc.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8192ee/sw.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/phydm/halrf/rtl8822b/halrf_8822b.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8192se/sw.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8192ee/table.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8192ee/trx.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8723ae/hal_bt_coexist.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8192se/table.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/phydm/halrf/rtl8822b/halrf_iqk_8822b.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8192se/trx.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8723ae/hw.o
LD [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8192ee/rtl8192ee.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8723be/dm.o
LD [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8192se/rtl8192se.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8723com/main.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/phydm/rtl8822b/halhwimg8822b_bb.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8723com/dm_common.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8723be/fw.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/phydm/rtl8822b/halhwimg8822b_mac.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8723ae/led.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8723com/fw_common.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8723be/hw.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/phydm/rtl8822b/halhwimg8822b_rf.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8723ae/phy.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8723com/phy_common.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8723ae/pwrseq.o
LD [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8723com/rtl8723-common.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/phydm/rtl8822b/phydm_hal_api8822b.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8723de/fw.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8723be/led.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8723ae/rf.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8723be/phy.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8723de/hw.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/phydm/rtl8822b/phydm_regconfig8822b.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8723ae/sw.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/phydm/rtl8822b/phydm_rtl8822b.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8723ae/table.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8723ae/trx.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8723be/pwrseq.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8723de/led.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/phydm/rtl8723d/halhwimg8723d_bb.o
LD [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8723ae/rtl8723ae.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8821ae/dm.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8723be/rf.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8723de/phy.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/phydm/rtl8723d/halhwimg8723d_mac.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8723be/sw.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8821ae/fw.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/phydm/rtl8723d/halhwimg8723d_rf.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8723de/pwrseq.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8723be/table.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8723be/trx.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8723de/rf.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/phydm/rtl8723d/phydm_regconfig8723d.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8821ae/hw.o
LD [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8723be/rtl8723be.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8822be/fw.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8723de/sw.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/phydm/rtl8723d/phydm_rtl8723d.o
/var/lib/dkms/rtlwifi-new/0.6/build/rtl8821ae/hw.c: In function ‘_rtl8821ae_mrate_idx_to_arfr_id’:
/var/lib/dkms/rtlwifi-new/0.6/build/rtl8821ae/hw.c:3453:8: warning: this statement may fall through [-Wimplicit-fallthrough=]
ret = 7;
/var/lib/dkms/rtlwifi-new/0.6/build/rtl8821ae/hw.c:3454:2: note: here
case RATR_INX_WIRELESS_AC_5N:
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/phydm/halrf/rtl8723d/halrf_8723d.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8723de/table.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8822be/hw.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8723de/trx.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8821ae/led.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/phydm/rtl_phydm.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8821ae/phy.o
LD [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8723de/rtl8723de.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/base.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8822be/led.o
/var/lib/dkms/rtlwifi-new/0.6/build/rtl8821ae/phy.c: In function ‘_rtl8812ae_phy_set_rfe_reg_24g’:
/var/lib/dkms/rtlwifi-new/0.6/build/rtl8821ae/phy.c:389:6: warning: this statement may fall through [-Wimplicit-fallthrough=]
if (rtlpriv->btcoexist.bt_coexistence) {
/var/lib/dkms/rtlwifi-new/0.6/build/rtl8821ae/phy.c:397:2: note: here
case 0:
LD [M] /var/lib/dkms/rtlwifi-new/0.6/build/phydm/phydm_mod.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8822be/phy.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/cam.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/core.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/debug.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8822be/sw.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8821ae/pwrseq.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/efuse.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/ps.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8822be/trx.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8821ae/rf.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rc.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/regd.o
LD [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8822be/rtl8822be.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/stats.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8821ae/sw.o
/var/lib/dkms/rtlwifi-new/0.6/build/rc.c: In function ‘rtl_get_rate’:
/var/lib/dkms/rtlwifi-new/0.6/build/rc.c:191:6: error: implicit declaration of function ‘rate_control_send_low’; did you mean ‘rate_control_set_rates’? [-Werror=implicit-function-declaration]
if (rate_control_send_low(sta, priv_sta, txrc))
cc1: some warnings being treated as errors
make[1]: *** [scripts/Makefile.build:281: /var/lib/dkms/rtlwifi-new/0.6/build/rc.o] Error 1
make[1]: *** Waiting for unfinished jobs....
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8821ae/table.o
CC [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8821ae/trx.o
LD [M] /var/lib/dkms/rtlwifi-new/0.6/build/rtl8821ae/rtl8821ae.o
make: *** [Makefile:1624: _module_/var/lib/dkms/rtlwifi-new/0.6/build] Error 2
make: Leaving directory '/usr/src/linux-headers-5.3.0-050300rc6-generic'
