When I enter the command:
sudo apt install libstdc++6:i386
I get the output:
 libstdc++6 : Breaks: libstdc++6:i386 (!= 8.2.0-1ubuntu2~18.04) but 8-20180414-1ubuntu2 is to be installed
 libstdc++6:i386 : Depends: gcc-8-base:i386 (= 8-20180414-1ubuntu2) but 8.2.0-1ubuntu2~18.04 is to be installed
                   Breaks: libstdc++6 (!= 8-20180414-1ubuntu2) but 8.2.0-1ubuntu2~18.04 is to be installed
 E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
This answer (https://askubuntu.com/a/1104999/772004) shows that 8.2.0-1ubuntu2~18.04 refers to the "bionic-updates" repository, while 8-20180414-1ubuntu2 refers to the "bionic" repository.
Why are these packages in conflict? What does it mean that a different package is "to be installed"? Finally, how can I resolve the issue?
Edit: I did figure out a solution. I needed to add the bionic-updates and bionic-security repositories to my sources.list file. Also, Sophos AV was causing some trouble with apt. Once I changed sources.list and uninstalled Sophos AV, I was able to update and resolve all dependency issues.
enivium
  • 51
In order to fix this, I needed to edit my /etc/apt/sources.list file.
I had only the line:
deb http://archive.ubuntu.com/ubuntu bionic main universe restricted multiverse
and I needed to add the lines:
deb http://archive.ubuntu.com/ubuntu bionic-security main universe restricted multiverse
deb http://archive.ubuntu.com/ubuntu bionic-updates main universe restricted multiverse
to add the bionic-security and bionic-updates repositories. Afterward I still had some trouble, which turned out to be related to Sophos AV. After unintstalling Sophos AV,
sudo apt update
sudo apt upgrade
fixed all the dependencies.
enivium
  • 51
