I am trying to install lalsuite on ubuntu according to the instructions here:
https://pycbc.org/pycbc/latest/html/install_lalsuite.html
Everything went smoothly until I ran
./00boot
./configure --prefix=${VIRTUAL_ENV}/opt/lalsuite --enable-swig-python
And the error I get is:
configure: error: could not find the zlib library
I am doing all this inside a virtual environment using virtualenv. I'm fairly certain I have the zlib library as I installed it with:
$ sudo apt install zlib1g
After a thorough search for a solution I found someone with the same problem:
https://ubuntuforums.org/showthread.php?t=2217198&page=2&s=3d14badd56b8ebb236dfc0970ba19435
But I do not really understand their solution. My interpretation of their fix was to do the following:
First reinstall pkg-config:
sudo apt-get update
sudo apt-get install pkg-config
Then write the line suggested by the answer:
echo 'export PKG_CONFIG=/usr/bin/pkg-config' >> ~/.bashrc
(I am doing all this inside the virtualenv by the way).
Then restart everything and try the same thing again:
./00boot
Sadly the same error appears.
Any help is appreciated.
