Few days ago, I installed Ubuntu on my PC, everything works fine.
It happened that I traveled to another country and I am still there. So whenever I run the update or try to install anything from Ubuntu Software, nothing works, although my internet works fine and I can access to internet using my PC (I am using it now to write these lines).
I tried to change the server to one of the country's servers where I am now, but it didn't work. So I changed to the Ubuntu main server, it also didn't work.
I restarted my PC, run sudo apt autoclean and sudo apt clean, nothing changed.
I still get these errors whenever I run the update process:
sudo apt update
Ign:1 http://archive.canonical.com/ubuntu bionic InRelease
Err:2 http://archive.canonical.com/ubuntu bionic Release
404 Not Found [IP: 91.189.92.191 80]
Ign:3 http://archive.ubuntu.com/ubuntu bionic InRelease
Ign:4 http://archive.ubuntu.com/ubuntu bionic-updates InRelease
Ign:5 http://archive.ubuntu.com/ubuntu bionic-backports InRelease
Ign:6 http://archive.ubuntu.com/ubuntu bionic-security InRelease
Err:7 http://archive.ubuntu.com/ubuntu bionic Release
404 Not Found [IP: 91.189.88.174 80]
Err:8 http://archive.ubuntu.com/ubuntu bionic-updates Release
Err:9 http://archive.ubuntu.com/ubuntu bionic-backports Release
Err:10 http://archive.ubuntu.com/ubuntu bionic-security Release
Reading package lists... Done
E: The repository 'http://archive.canonical.com/ubuntu bionic Release' no longer has a Release file.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
E: The repository 'http://archive.ubuntu.com/ubuntu bionic Release' does not have a Release file.
E: The repository 'http://archive.ubuntu.com/ubuntu bionic-updates Release' does not have a Release file.
E: The repository 'http://archive.ubuntu.com/ubuntu bionic-backports Release' does not have a Release file.
E: The repository 'http://archive.ubuntu.com/ubuntu bionic-security Release' does not have a Release file.
Anyone knows how to fix this?
EDIT:
The problem is not that I don't have the right links in /etc/apt/sources.list. My problem is that when I run the update, the links that appear in the terminal are not similar to the ones I have in /etc/apt/sources.list
Also when I updated /etc/apt/sources.list as Raffa said, I still get similar errors.
sudo apt update
Ign:1 http://archive.ubuntu.com/ubuntu bionic InRelease
Ign:2 http://security.ubuntu.com/ubuntu bionic-security InRelease
Ign:3 http://archive.ubuntu.com/ubuntu bionic-updates InRelease
Err:4 http://security.ubuntu.com/ubuntu bionic-security Release
404 Not Found [IP: 91.189.91.14 80]
Err:5 http://archive.ubuntu.com/ubuntu bionic Release
404 Not Found [IP: 91.189.88.31 80]
Err:6 http://archive.ubuntu.com/ubuntu bionic-updates Release
E: The repository 'http://security.ubuntu.com/ubuntu bionic-security Release' no longer has a Release file.
Although /etc/apt/sources.list contains the links mentioned by Raffa
cat /etc/apt/sources.list
deb http://archive.ubuntu.com/ubuntu bionic main universe multiverse restricted
deb http://security.ubuntu.com/ubuntu/ bionic-security main multiverse universe restricted
deb http://archive.ubuntu.com/ubuntu bionic-updates main multiverse universe restricted
