86
I followed composer manual (global installation of composer (manual)) to install composer on Ubuntu.
$ ll /usr/local/bin/
total 4760
drwxr-xr-x  2 root root    4096 2012-03-29 08:29 ./
drwxr-xr-x 10 root root    4096 2011-04-26 00:50 ../
-rwxr-xr-x  1 root root  410324 2012-03-29 08:28 composer.phar
Other scripts from /usr/local/bin/ works, but composer gives:
$php composer.phar update Could not open input file: composer.phar
It works only if I enter absolute path to composer.phar. How to fix this?
muru
  • 207,228
umpirsky
  • 3,852
8 Answers8
200
TLDR;
As described on the Composer website:
curl -sS https://getcomposer.org/installer | php
sudo mv composer.phar /usr/local/bin/composer
Manual Method
I found an easier way to globally install composer than the manual proscribed in the github readme.md. It's actually on the getcomposer.org website:
curl -s http://getcomposer.org/installer | php
And if you're even more lazy, like me, you can create an alias:
alias composer='/usr/local/bin/composer.phar'
This way you can invoke composer with just composer
29
Don't add php in the beginning. Just call composer.phar.
Eliah Kagan
  • 119,640
garakkio
  • 756
28
Actually, getcomposer.org now recommends a simpler method:
$ curl -sS https://getcomposer.org/installer | php
$ sudo mv composer.phar /usr/local/bin/composer
Now you can just use composer without bothering with an alias or a separate sh script.
Another alternative to get a nice composer command instead of composer.phar:
$ curl -sS https://getcomposer.org/installer | php -- --install-dir=/usr/local/bin
$ ln -s /usr/local/bin/composer.phar /usr/local/bin/composer
for easier execution I created /usr/local/bin/composer with content:
#!/bin/sh
exec /usr/local/bin/composer.phar "$@"
dont forget about sudo chmod +x /usr/local/bin/composer.phar
Eliah Kagan
  • 119,640
Below are the steps to be followed to install composer globally: 1. Before installing Composer, make sure our server has all dependencies installed.
1st, update the package manager cache by running:
$ sudo apt-get update
2. Now, let's install the dependencies. We'll need
  • curl => to download Composer
  • php5-cli => installing and running it
  • git => used by Composer for downloading project dependencies
Everything can be installed with the following command:
$ sudo apt-get install curl php5-cli git
3. Composer installation with a single command:
curl -sS https://getcomposer.org/installer | sudo php -- --install-dir=/usr/local/bin --filename=composer
4. This will download and install Composer as a system-wide command named composer, under /usr/local/bin. The output should look like this:
Output:
\#!/usr/bin/env php
All settings correct for using Composer
Downloading...
Composer successfully installed to: /usr/local/bin/composer
Use it: php /usr/local/bin/composer
5. To test your installation, run:
$ composer -V
Output:
Composer version 1.1.3 2016-06-26 15:42:08
  1. Installation Successful
Ravistm
  • 131
I have made a simple bash script that automatically installs composer for current user/all users, you can one of the following commands in your terminal to use bash script.
Current User
wget -O - https://gist.github.com/EmpireWorld/1dd5f59566e186907f99dc16badc382a/raw/install-composer-local.sh | bash
All Users
wget -O - https://gist.github.com/EmpireWorld/1dd5f59566e186907f99dc16badc382a/raw/install-composer-global.sh | bash
Check out the Gist
Hasan Bayat
  • 107
This might work for you. Note that sudo is used two times here.
sudo curl -sS https://getcomposer.org/installer | sudo php
grooveplex
  • 2,506
  • 27
  • 35
