I encountered error like "(user in plugdev group; are your udev rules wrong?", After googled, I found some key refers:
- Ref 1. Set up a device for development from Android Developer;
- Ref 2. Solved: no permissions (user in plugdev group; are your udev rules wrong?): Solution 3;
- Ref 3. Android udev rules list aimed to be the most comprehensive on the net;
It seems I should have fixed my error since I found Ref 2 as above; As Android Developer docs say:
Ubuntu Linux: Use
apt-get installto install theadbpackage. This gives you a community-maintained default set ofudevrules for all Android devices.
I was confused because I had env variable ANDROID_HOMEon 16.04LTS(my current use) and export two below which I DO NOT install adb with apt-get install adb.
# set android adb tools
export ANDROID_HOME=$HOME/Android/Sdk
export PATH=$PATH:$ANDROID_HOME/tools:$ANDROID_HOME/platform-tools
I checked /etc/udev/rules.d/ which have 170-snap.core.rules 70-snap.vlc.rules. Was that(not install apt-get install adb) I missed this file /etc/udev/rules.d/51-android.rules? Answer is NO.
- Which adb package I should use on Ubuntu 16.04LTS, "~/Android/Sdk/platform-tools/adb" or "sudo apt-get adb"?
As danzel(nice and humorous person below) and Andoroid developer docs suggest, I keep two export as mentioned above and
sudo apt-get install adbfor a community-maintained default set of udev rules for all Android devices. - Should I add this
51-android.rulesto/etc/udev/rules.d/meanwhile I backup thoes two70-snap.core.rules 70-snap.vlc.rules?- They have no relationship.
- As Android developer docs(webpage language as Chinese or '中文-简体') say, developers create
/etc/udev/rules.d/51-android.rulesfile as root orsudocommand, usechmod a+r /etc/udev/rules.d/51-android.ruleschange privilege of this file. Add rule into this file, check Solution 3. - Other files are NOT mentioned, so don't touch them.
- Will be caused unreversed errors for my developer computer env?
I laughed myself just as danzel(nice and humorous person below) said
"the inverse operation of creating a file is deleting it";
Latest updated: 2019-09-02
