I need to configure UFW or iptables to secure Kamailio on my ubuntu server. I followed this kamailio-security but I don't know how to configure it.
*filter
:INPUT DROP [0:0]
:FORWARD DROP [0:0]
:OUTPUT DROP [0:0]
:CHECK_TCP - [0:0]
:ICMP - [0:0]
:PRIVATE - [0:0]
:PSD - [0:0]
:SERVICES - [0:0]
-A INPUT -i lo -j ACCEPT
-A INPUT -i eth0 -p ipv6 -j ACCEPT
-A INPUT -m state --state RELATED,ESTABLISHED -j ACCEPT
-A INPUT -j SERVICES
-A OUTPUT -o lo -j ACCEPT
-A OUTPUT -m state --state NEW,RELATED,ESTABLISHED -j ACCEPT
-A CHECK_TCP -p tcp -m tcp ! --tcp-flags SYN,RST,ACK SYN -m state --state NEW -j DROP
-A CHECK_TCP -p tcp -m tcp --tcp-flags FIN,SYN,RST,PSH,ACK,URG FIN,SYN,RST,ACK -j DROP
-A CHECK_TCP -p tcp -m tcp --tcp-flags FIN,SYN,RST,PSH,ACK,URG FIN,PSH,URG -j DROP
-A CHECK_TCP -p tcp -m tcp --tcp-flags FIN,ACK FIN -m state --state INVALID,NEW,RELATED -j DROP
-A CHECK_TCP -p tcp -m tcp --tcp-flags FIN,SYN,RST,PSH,ACK,URG FIN,SYN -j DROP
-A CHECK_TCP -p tcp -m tcp --tcp-flags FIN,SYN FIN,SYN -j DROP
-A CHECK_TCP -p tcp -m tcp --tcp-flags SYN,RST SYN,RST -j DROP
-A CHECK_TCP -p tcp -m tcp --tcp-flags FIN,RST FIN,RST -j DROP
-A CHECK_TCP -p tcp -m tcp --tcp-flags PSH,ACK PSH -j DROP
-A CHECK_TCP -p tcp -m tcp --tcp-flags ACK,URG URG -j DROP
-A CHECK_TCP -p tcp -m tcp --tcp-flags FIN,SYN,RST,PSH,ACK,URG NONE -j DROP
-A CHECK_TCP -p tcp -m tcp --tcp-flags FIN,SYN,RST,PSH,ACK,URG FIN,SYN,RST,PSH,ACK,URG -j DROP
-A CHECK_TCP -p tcp -m tcp --tcp-option 64 -j DROP
-A CHECK_TCP -p tcp -m tcp --tcp-option 128 -j DROP
-A ICMP -p icmp -m icmp --icmp-type 11/1 -m limit --limit 5/sec -m state --state NEW -j ACCEPT
-A ICMP -p icmp -m icmp --icmp-type 11/0 -m limit --limit 5/sec -m state --state NEW -j ACCEPT
-A ICMP -p icmp -m icmp --icmp-type 3 -m limit --limit 10/sec -m state --state NEW -j ACCEPT
-A ICMP -p icmp -m icmp --icmp-type 8 -m limit --limit 10/sec --limit-burst 10 -m state --state NEW -j ACCEPT
-A ICMP -p icmp -j DROP
-A PRIVATE -d 192.168.0.0/16 -j DROP
-A PRIVATE -d 172.16.0.0/12 -j DROP
-A PRIVATE -d 10.0.0.0/8 -j DROP
-A PRIVATE -j RETURN
-A PSD -p tcp -m statistic --mode random --probability 0.050000 -j REJECT --reject-with icmp-port-unreachable
-A PSD -p tcp -m statistic --mode random --probability 0.050000 -j TARPIT  --reset
-A PSD -p tcp -m statistic --mode random --probability 0.500000 -j TARPIT  --tarpit
-A PSD -p udp -m statistic --mode random --probability 0.050000 -j REJECT --reject-with icmp-port-unreachable
-A PSD -m statistic --mode random --probability 0.050000 -j REJECT --reject-with icmp-host-unreachable
-A SERVICES -p icmp -m state --state INVALID -j DROP
-A SERVICES -p icmp -j ICMP
-A SERVICES -p tcp -j CHECK_TCP
-A SERVICES -p udp -m udp --dport 123 -m state --state NEW -j ACCEPT
-A SERVICES -p udp -m udp --dport 53 -m state --state NEW -j ACCEPT
-A SERVICES -p tcp -m tcp --dport 53 -m state --state NEW -j ACCEPT
-A SERVICES -p tcp -m udp -m multiport --dports 5060 -m state --state NEW -j ACCEPT
-A SERVICES -p tcp -m udp -m multiport --dports 5061 -m state --state NEW -j ACCEPT
-A SERVICES -i eth0 -j PSD
COMMIT
Kamailio is a SIP and optional RTP server
So you have to allow SIP and optionally RTP protocols
The document you referring to also allows DNS and NTP
A good advice in the document suggest to use fail2ban, if your Kamailio server has to be exposed to the public Internet network, then fail2ban should be implemented.
# Allows SIP
sudo ufw allow 5060:5061/udp
# Allow RTP (optional)
sudo ufw allow 10000:20000/udp
# Allows DNS
sudo ufw allow 53/udp
sudo ufw allow 53/tcp
# Allow NTP
sudo ufw allow 123/udp
You can add comment to rules, specify ip adress of the server, and many more.
See the ufw documentation and ufw man page
cmak.fr
  • 8,976
