I tried installing fbreader, following all the steps, but ended up with unmet dependencies, i also think a file is referenced in two locations at once and hence killing it..
any ideas how I can fix it? i've done alot of research and tried:
simon@simon-Studio-1558:~$ sudo apt-get -f install
Reading package lists... Done
Building dependency tree
Correcting dependencies... Done
The following packages were automatically installed and are no longer required:
  dkms patch
Use 'apt-get autoremove' to remove them.
The following extra packages will be installed:
  libzlcore0.12
The following NEW packages will be installed:
  libzlcore0.12
0 upgraded, 1 newly installed, 0 to remove and 61 not upgraded.
6 not fully installed or removed.
Need to get 0 B/270 kB of archives.
After this operation, 811 kB of additional disk space will be used.
Do you want to continue [Y/n]? y
(Reading database ... 179860 files and directories currently installed.)
Unpacking libzlcore0.12 (from .../libzlcore0.12_0.12.10dfsg-4_i386.deb) ...
dpkg: error processing /var/cache/apt/archives/libzlcore0.12_0.12.10dfsg-4_i386.deb (--unpack):
trying to overwrite '/usr/lib/libzlcore.so.0.12.10', which is also in package libzlcore 0.12.10-1
No apport report written because MaxReports is reached already
dpkg-deb: error: subprocess paste was killed by signal (Broken pipe)
sorry for the formatting, but it basically isn't liking:
Any ideas? Also I don't care about keeping the program, but the error is stopping
sudo apt-get remove fbreader
from working too.
zpletan
  • 3,443
Simon
  • 19
I had quite a similar error message:
dpkg: error processing /var/cache/apt/archives/gimp_2.8.0~rc1-0precise0~ppa_amd64.deb (--unpack):
trying to overwrite '/usr/lib/gimp/2.0/plug-ins/file-xmc', which is also in package gimp-plugin-registry 3.5.4-1 dpkg-deb:
And apt-get stopped working for me as well, wouldn't do anything useful anymore. Same for the software center, however synaptic would still work (at least kind of) and I could deinstall the conflicting package gimp-plugin-registry 3.5.4-1 with it.
So you might give it a shot with Synaptic, although I wouldn't know how to get it unto your system when apt-get isn't working and you haven't already installed it.
UPDATE: I think I have a hunch about a more generic approach to solving this issue. You could try dpkg - P libzlcore 0.12.10-1, but as I already solved my issue I can't test it myself.
Peachy
  • 7,235
  • 40
  • 47
I seem that your drive is full and has no free space. Try moving some unwanted files like to another partition and ,make some free space. Type
sudo apt-get install --fix-broken
KK Patel
  • 19,753
