Many shell applications are throwing SSL certificate errors. I'm not aware of anything that could have caused this. apt, Google Chrome, Discord all work fine.
Already tried: Problem with certificates
Examples:
YouTube-dl: <urlopen error [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:852)> (caused by URLError(SSLError(1, '[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:852)'),))
wget: ERROR: cannot verify www.google.com's certificate, issued by ‘CN=GTS CA 1O1,O=Google Trust Services,C=US’: Unable to locally verify the issuer's authority. To connect to www.google.com insecurely, use `--no-check-certificate'.
UPDATE:
The time on my machine is correct. (I checked just to be sure)
dpkg -l | grep cert comes up with the following packages:
ii  ca-certificates                            20180409                                     all          Common CA certificates
ii  ca-certificates-java                       20180516ubuntu1~18.04.1                      all          Common CA certificates (JKS keystore)
ii  dirmngr                                    2.2.4-1ubuntu1.2                             amd64        GNU privacy guard - network certificate management service
ii  python3-certifi                            2018.1.18-2                                  all          root certificates for validating SSL certs and verifying TLS hosts (python3)
ii  ssl-cert                                   1.0.39                                       all          simple debconf wrapper for OpenSSL
UPDATE 2:
which openssl succesfully returns that OpenSSL is installed in /usr/local/bin/openssl.
ldd $(which wget) returns:
    linux-vdso.so.1 (0x00007ffda9b23000)
    libpcre.so.3 => /lib/x86_64-linux-gnu/libpcre.so.3 (0x00007f2edddd0000)
    libuuid.so.1 => /lib/x86_64-linux-gnu/libuuid.so.1 (0x00007f2eddbc8000)
    libidn2.so.0 => /usr/lib/x86_64-linux-gnu/libidn2.so.0 (0x00007f2edd9a8000)
    libssl.so.1.1 => /usr/local/lib/libssl.so.1.1 (0x00007f2edd710000)
    libcrypto.so.1.1 => /usr/local/lib/libcrypto.so.1.1 (0x00007f2edd218000)
    libpsl.so.5 => /usr/lib/x86_64-linux-gnu/libpsl.so.5 (0x00007f2edd008000)
    libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f2edcc10000)
    libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007f2edc9f0000)
    /lib64/ld-linux-x86-64.so.2 (0x00007f2ede2d0000)
    libunistring.so.2 => /usr/lib/x86_64-linux-gnu/libunistring.so.2 (0x00007f2edc670000)
    libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007f2edc468000)
UPDATE 3:
dpkg -l | grep openssl returns:
ii  openssl                                                     1.1.1-1ubuntu2.1~18.04.4                                    amd64        Secure Sockets Layer toolkit - cryptographic utility
ii  perl-openssl-defaults:amd64                                 3build1                                                     amd64        version compatibility baseline for Perl OpenSSL packages
UPDATE 4:
sudo apt install --reinstall openssl solved wget, but python apps like youtube-dl and do-release-upgrade are still reporting certificate issues.
CONCLUSION
Reinstalled Ubuntu
Octelly
  • 141
The issue I found on my Ubuntu with Python was that I upgraded pip install --upgrade certifi... And then it took me hours trying to understand why things do not work... Only once I had seen different versions here, that I started thinking in the right direction...
vitaliy@vitalnuc01:~/HANAClientsTutorial/python$ dpkg -l | grep python3-certifi
vitaliy@vitalnuc01:~/HANAClientsTutorial/python$ pip3 search certifi
certifi (2020.4.5.1)                        - Python package for providing Mozilla's CA Bundle.
  INSTALLED: 2020.4.5.1 (latest)
So...
pip3 uninstall certifi
sudo apt-get install --reinstall python3-certifi
...and Python-based programs started working for me again.
And yes, I was close to reinstalling my Ubuntu as well :)
