I have an Ubuntu 18.04 host with two network interfaces on two subnets. I would like to set up symmetric routing so that traffic received from one interface is sent symmetrically out that same interface.
I know how to use Netplan for simple network configurations, but I'm stumped for more advanced configurations. Specifically:
- What is the Netplan syntax to add a default route like I do with
ip route add default via 192.168.0.1 dev ens192 tab 1? - How can I add a
prioritytag to a route?
My server has two IPs:
$ ip a|grep "inet "
inet 127.0.0.1/8 scope host lo
inet 192.168.0.10/22 brd 192.168.0.255 scope global ens192
inet 192.168.1.10/24 brd 192.168.1.255 scope global ens224
I can use the following ip rules to get the tables that I want:
First, I create a route for each network and then add a default gateway.
$ ip route add 192.168.0.0/24 dev ens192 tab 1
$ ip route add 192.168.1.0/24 dev ens224 tab 2
$ ip route add default via 192.168.0.1 dev ens192 tab 1
$ ip route add default via 192.168.1.1 dev ens224 tab 2
Then, I can create corresponding rules:
$ ip rule add from 192.168.0.10/32 tab 1 priority 100
$ ip rule add from 192.168.1.10/32 tab 2 priority 200
$ ip route flush cache
This gets the routes that I want:
$ ip route show tab 1
$ ip route show tab 2
$ ip route
default via 192.168.0.10 dev ens192
As well as the rules that I want:
$ ip rule show
0: from all lookup local
100: from 192.168.0.10 lookup 1
200: from 192.168.1.10 lookup 2
32766: from all lookup main
32767: from all lookup default
