I'm using Ubuntu 18.04 and following this guide. When I entered sudo add-apt-repository ppa:graphics-drivers/ppa the terminal outputted this error message:
W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: http://download.opensuse.org/repositories/home:/strycore/xUbuntu_18.04 ./ Release: The following signatures were invalid: EXPKEYSIG 2F7F0DA5FD5B64B9 home:strycore OBS Project <home:strycore@build.opensuse.org>
E: Repository 'http://ppa.launchpad.net/webupd8team/java/ubuntu bionic InRelease' changed its 'Label' value from 'Oracle Java (JDK) 8 Installer PPA' to 'Oracle Java (JDK) 8 Installer PPA (DISCONTINUED)'
N: This must be accepted explicitly before updates for this repository can be applied. See apt-secure(8) manpage for details.
What should I do? How can I update the graphic driver?
Entering sudo apt-install nvidia-driver-430 gives the error message:
The following information may help resolve the situation:
 nvidia-driver-430 : Depends: libnvidia-gl-430 (= 430.40-0ubuntu0~gpu18.04.1) but it is not going to be installed
                     Depends: nvidia-dkms-430 (= 430.40-0ubuntu0~gpu18.04.1) but it is not going to be installed
                     Depends: nvidia-kernel-source-430 (= 430.40-0ubuntu0~gpu18.04.1) but it is not going to be installed
                     Depends: libnvidia-compute-430 (= 430.40-0ubuntu0~gpu18.04.1) but it is not going to be installed
                     Depends: nvidia-compute-utils-430 (= 430.40-0ubuntu0~gpu18.04.1) but it is not going to be installed
                     Depends: libnvidia-decode-430 (= 430.40-0ubuntu0~gpu18.04.1) but it is not going to be installed
                     Depends: libnvidia-encode-430 (= 430.40-0ubuntu0~gpu18.04.1) but it is not going to be installed
                     Depends: nvidia-utils-430 (= 430.40-0ubuntu0~gpu18.04.1) but it is not going to be installed
                     Depends: libnvidia-ifr1-430 (= 430.40-0ubuntu0~gpu18.04.1) but it is not going to be installed
                     Recommends: libnvidia-compute-430:i386 (= 430.40-0ubuntu0~gpu18.04.1)
                     Recommends: libnvidia-decode-430:i386 (= 430.40-0ubuntu0~gpu18.04.1)
                     Recommends: libnvidia-encode-430:i386 (= 430.40-0ubuntu0~gpu18.04.1)
                     Recommends: libnvidia-ifr1-430:i386 (= 430.40-0ubuntu0~gpu18.04.1)
Eliah Kagan
  • 119,640
You can install Nvidia 430 driver without adding any PPA.
sudo apt install nvidia-driver-430
https://packages.ubuntu.com/search?keywords=Nvidia&searchon=names&suite=bionic-updates&section=all
adasiko
  • 409
