I have a Kubuntu 18.04 installed and I've been playing around with my Nvidia driver (I confess). By that, I mean that I had Nvidia driver 430 installed and working completely. But then since I could not make Nvidia PRIME work, I uninstalled the driver and reinstalled it. I believe I've done that more than a couple of times (maybe one too many).
Anyways, the last time I installed the driver, it worked just like any time before that. But then after a reboot, the resolution is now locked on something pretty low. After some searching online, I found that it might mean that the driver is not properly loaded. And I need to disable the secure boot. But then, I remembered that I had done this before and in fact each time I boot the system, before grub menu, it says Booting in insecure mode. Still, I followed the instructions on this post but of course, you cannot disable something that is already disabled!
To give you a little bit more information:
$ sudo lshw -c display
*-display UNCLAIMED
description: VGA compatible controller
product: GP102 [GeForce GTX 1080 Ti]
vendor: NVIDIA Corporation
physical id: 0
bus info: pci@0000:01:00.0
version: a1
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress vga_controller bus_master cap_list
configuration: latency=0
resources: memory:f6000000-f6ffffff memory:e0000000-efffffff memory:f0000000-f1ffffff ioport:e000(size=128) memory:c0000-dffff
Does anyone know how to install my Nvidia driver properly?
