I need to stop execution of a running java script in terminal and start the same execution at every x interval of time in terminal. Is it possible?
Asked
Active
Viewed 88 times
Yes, /usr/bin/timeout is the tool to use. See man timeout. Here is an example, from one of my nightly cron jobs, you can wrap yours in a while true ; do loop:
TO_KILL="45m" # timeout (kill -KILL) for hpodder
TO_HUP="42m" # timeout (kill -HUP) for hpodder. Makes sense only if it is less than $TO_KILL
timeout -k $TO_KILL -s HUP $TO_HUP hpodder update
This will run the hpodder update until it finishes, or 42 minutes have passed, when it will be sent (see man 7 signal) a HUP signal. If hpodder update is still running after 45 minutes (3 minutes after the HUP was sent), it will be sent the uncatchable KILL signal, and will be terminated.
waltinator
- 37,856
