This website explains MySQL server installation in Ubuntu 18.04. Basically you issue the command sudo apt install mysql-server. The same website then explains that:
Once the installation is completed, the MySQL service will start automatically. To check whether the MySQL server is running, type: sudo systemctl status mysql
Does this imply that once I install mysql-server it will always be running in the background unless I explicitly kill the process upon each reboot?
I want to play around with mysql-server occasionally, but don't want it constantly running in the background.
Display name
  • 2,331
Yes.
No, never ever ever kill mysql. Killing it can damage your database.
  • sudo service mysql stop will stop the current session
  • sudo systemctl disable mysql to prevent it starting on boot. That is done once and makes it disabled each boot. sudo service mysql start will start mysql when disabled.
Rinzwind
  • 309,379
