I want to install PostgreSQL on my Ubuntu 16.04 machine.
After running this command:
sudo apt-get install postgresql postgresql-contrib
I get the following:
Reading package lists... Done
Building dependency tree
 gir1.2-rb-3.0 : Depends: librhythmbox-core9 (>= 3.3) but it is not going to be installed
 gnome-control-center : Depends: libgoa-backend-1.0-1 (>= 3.10.0) but it is not going to be installed
 indicator-datetime : Depends: libecal-1.2-16 (>= 3.7.90) but it is not going to be installed
                      Depends: libedataserver-1.2-18 (>= 3.5.91) but it is not going to be installed
                      Recommends: evolution-data-server but it is not going to be installed
                      Recommends: geoclue-ubuntu-geoip but it is not going to be installed or
                                  geoclue-provider
                      Recommends: unity-control-center (>= 14.04.3) but it is not going to be installed or
                                  ubuntu-system-settings but it is not going to be installed
 libcheese7 : Depends: gstreamer1.0-plugins-good (>= 0.11.0) but it is not going to be installed
 libgphoto2-dev : Depends: libgphoto2-6 (= 2.5.3.1-1ubuntu2.2) but 2.5.9-3 is to be installed
 libgtk-3-0 : Depends: librest-0.7-0 (>= 0.7) but it is not going to be installed
 libnice10 : Depends: libgupnp-igd-1.0-4 (>= 0.2.4) but it is not going to be installed
 network-manager-gnome : Depends: network-manager (>= 0.9.8) but it is not going to be installed
 plainbox-provider-checkbox : Depends: plainbox-provider-resource-generic (>= 0.3) but it is not going to be installed
                              Recommends: gstreamer1.0-plugins-good but it is not going to be installed
 ubuntu-release-upgrader-gtk : Depends: gir1.2-webkit2-4.0 but it is not going to be installed or
                                        gir1.2-webkit-3.0 but it is not going to be installed
 ubuntu-sso-client : Depends: python-ubuntu-sso-client (= 13.10-0ubuntu11) but it is not going to be installed
 yelp : Depends: libwebkitgtk-3.0-0 (>= 1.3.10) but it is not going to be installed
        Depends: libyelp0 (= 3.10.2-0ubuntu1) but it is not going to be installed
 zenity : Depends: libwebkit2gtk-4.0-37 (>= 2.5.3) but it is not going to be installed
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
How should I proceed?
EDIT:
The first 220 lines of the output of apt-cache policy postgresql* (shortened because of the rule about the maximal number of characters in a code environment):
libghc-haskelldb-hdbc-postgresql-dev:
  Installed: (none)
  Candidate: 2.1.2-7build1
  Version table:
     2.1.2-7build1 0
        500 http://cz.archive.ubuntu.com/ubuntu/ xenial/universe amd64 Packages
     2.1.2-3build1 0
        500 http://rs.archive.ubuntu.com/ubuntu/ trusty/universe amd64 Packages
postgresql-prioritize:
  Installed: (none)
  Candidate: 1.0.4-1
  Version table:
     1.0.4-1 0
libghc-haskelldb-hdbc-postgresql-prof:
  Installed: (none)
  Version table:
     2.1.2-7build1 0
     2.1.2-3build1 0
postgresql-9.3-pgfincore:
  Installed: (none)
  Candidate: 1.1.2-1
  Version table:
     1.1.2-1 0
postgresql-9.5-slony1-2:
  Installed: (none)
  Candidate: 2.2.4-3
  Version table:
     2.2.4-3 0
postgresql-9.3-pgrouting:
  Installed: (none)
  Candidate: 2.2.3-1~trusty1
  Version table:
     2.2.3-1~trusty1 0
        500 http://ppa.launchpad.net/ubuntugis/ppa/ubuntu/ trusty/main amd64 Packages
postgresql-9.3-repmgr-dbg:
  Installed: (none)
  Candidate: (none)
  Version table:
libghc-persistent-postgresql-prof:
  Installed: (none)
  Candidate: 2.2.1.2-1build1
  Version table:
     2.2.1.2-1build1 0
     1.2.1-1build5 0
postgresql-9.5-dbg:
  Installed: (none)
  Candidate: 9.5.2-1
  Version table:
     9.5.2-1 0
        500 http://cz.archive.ubuntu.com/ubuntu/ xenial/main amd64 Packages
tarantool-lts-postgresql-module:
  Installed: (none)
  Candidate: 1.5.5-18-g2998d20-1ubuntu1
  Version table:
     1.5.5-18-g2998d20-1ubuntu1 0
postgresql-comparator:
  Installed: (none)
  Candidate: 2.2.6-2
  Version table:
     2.2.6-2 0
     2.2.2-1 0
libpostgresql-ocaml:
  Installed: (none)
  Candidate: 2.0.5-2build1
  Version table:
     2.0.5-2build1 0
     2.0.5-1 0
postgresql-9.3-slony1-2:
  Installed: (none)
  Candidate: 2.1.4-1ubuntu1
  Version table:
     2.1.4-1ubuntu1 0
postgresql-9.0:
  Installed: (none)
  Candidate: (none)
  Version table:
postgresql-9.1:
  Installed: (none)
  Candidate: (none)
  Version table:
postgresql-9.2:
  Installed: (none)
  Candidate: (none)
  Version table:
postgresql-9.3:
  Installed: (none)
  Candidate: 9.3.24-0ubuntu0.14.04
  Version table:
     9.3.24-0ubuntu0.14.04 0
        500 http://rs.archive.ubuntu.com/ubuntu/ trusty-updates/main amd64 Packages
        500 http://security.ubuntu.com/ubuntu/ trusty-security/main amd64 Packages
     9.3.4-1 0
        500 http://rs.archive.ubuntu.com/ubuntu/ trusty/main amd64 Packages
postgresql-9.3-postgis-2.0-scripts:
  Installed: (none)
  Candidate: (none)
  Version table:
postgresql-9.4:
  Installed: (none)
  Candidate: (none)
  Version table:
postgresql-9.5:
  Installed: (none)
  Candidate: 9.5.2-1
  Version table:
     9.5.2-1 0
postgresql-9.5-debversion:
  Installed: (none)
  Candidate: 1.0.8-1
  Version table:
     1.0.8-1 0
libapq-postgresql-dev:
  Installed: (none)
  Candidate: (none)
  Version table:
libapq-postgresql3.2.0-dbg:
  Installed: (none)
  Candidate: 3.2.0-2
  Version table:
     3.2.0-2 0
postgresql-plpython-9.3:
  Installed: (none)
  Version table:
     9.3.4-1 0
postgresql-plpython-9.5:
  Installed: (none)
  Candidate: 9.5.2-1
  Version table:
     9.5.2-1 0
postgresql-9.3-postgis:
  Installed: (none)
  Candidate: (none)
  Version table:
postgresql-9.3-orafce:
  Installed: (none)
  Candidate: 3.0.6-1
  Version table:
     3.0.6-1 0
postgresql-9.5-pllua:
  Installed: (none)
  Candidate: 1:1.0-6
  Version table:
     1:1.0-6 0
libghc-postgresql-simple-dev-0.3.4.0-e9568:
  Installed: (none)
  Candidate: (none)
  Version table:
libghc-postgresql-libpq-prof:
  Installed: 0.8.2.1-2
  Candidate: 0.9.1.1-3
  Version table:
     0.9.1.1-3 0
 *** 0.8.2.1-2 0
        100 /var/lib/dpkg/status
postgresql-plv8:
  Installed: (none)
  Candidate: (none)
  Version table:
libghc-persistent-postgresql-dev:
  Installed: (none)
  Version table:
     2.2.1.2-1build1 0
     1.2.1-1build5 0
libghc-postgresql-simple-prof-0.3.4.0-e9568:
  Installed: (none)
  Candidate: (none)
  Version table:
libghc-hdbc-postgresql-dev-2.3.2.1-90dce:
  Installed: (none)
  Candidate: (none)
  Version table:
postgresql-9.0-repmgr-dbg:
  Installed: (none)
  Candidate: (none)
  Version table:
postgresql-server-dev-9.3:
  Installed: (none)
  Version table:
     9.3.4-1 0
postgresql-server-dev-9.5:
  Installed: (none)
  Candidate: 9.5.2-1
  Version table:
     9.5.2-1 0
Milos
  • 101
