I recently installed mongodb on my ubuntu 18.04. After that when i try installing any package using apt, I get this error.
$sudo apt-get install shutter
Reading package lists... Done
Building dependency tree
You might want to run 'apt --fix-broken install' to correct these.
mongodb-org : Depends: mongodb-org-tools but it is not going to be installed
shutter : Depends: libgtk2-perl but it is not going to be installed
       Depends: libgnome2-perl but it is not going to be installed
       Depends: libgnome2-vfs-perl but it is not going to be installed
       Depends: libgnome2-wnck-perl but it is not going to be installed
       Depends: libgnome2-gconf-perl but it is not going to be installed
       Depends: libwww-mechanize-perl but it is not going to be installed
       Depends: libimage-magick-perl but it is not going to be installed
       Depends: libproc-simple-perl but it is not going to be installed
       Depends: libfile-which-perl but it is not going to be installed
       Depends: libsort-naturally-perl but it is not going to be installed
       Depends: libgtk2-imageview-perl but it is not going to be installed
       Depends: libgnome2-canvas-perl but it is not going to be installed
       Depends: libgtk2-unique-perl but it is not going to be installed
       Depends: libproc-processtable-perl but it is not going to be installed
       Depends: libpath-class-perl but it is not going to be installed
       Depends: libjson-perl but it is not going to be installed
       Depends: libjson-xs-perl but it is not going to be installed
       Depends: libnet-dropbox-api-perl but it is not going to be installed
       Depends: libx11-protocol-other-perl but it is not going to be installed
       Recommends: libgoo-canvas-perl but it is not installable
       Recommends: libgtk2-appindicator-perl but it is not installable
       Recommends: libnet-oauth-perl but it is not going to be installed
 E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
i try using apt --fix-broken install. It tries installing mongodb-org-tools but just after unpacking , dpkg returns this:
Preparing to unpack .../mongodb-org-tools_4.2.0_amd64.deb ...
Unpacking mongodb-org-tools (4.2.0) ...
dpkg: error processing archive /var/cache/apt/archives/mongodb-org-tools_4.2.0_amd64.deb (--unpack):
 trying to overwrite '/usr/bin/bsondump', which is also in package mongo-tools 3.6.3-0ubuntu1
dpkg-deb: error: paste subprocess was killed by signal (Broken pipe)
How can I fix this?
Edit : The commands suggestd by @N0rbert don't work for me. Here's the output to the commands he listed
$ sudo add-apt-repository universe
'universe' distribution component is already enabled for all sources.
$ sudo apt-get remove mongo-tools
Ash Klempton
  • 41
Two problems here -
  1. you have missed universe pocket. Enable it with:
    Fix your repositories as described in this answer if unsure.
  2. you have two sources for MongoDB package, remove older one with
And finally install Shutter with
N0rbert
  • 103,263
