I updated from Ubuntu 16.04 to Ubuntu 18.04 about 4 months ago and it worked properly for a while, but then I started getting a problem with a login loop. I can drop down into the command line and run commands, but I want to login into the GUI environment.
Emby was put on an old Windows 8 converted to 10 computer that I used.
ASUS M Series M51AC
Tower
Core i7 4770 3.4 GHz
RAM 16 GB
HDD 1 TB
BIOS Version: 0901
SN: XXXXXXXXXXXX
Display Hardware:
Results of lspci | grep VGA
01:00.0 VGA compatible controller: NVIDIA Corporation GF119 [GeForce GT 620 OEM] (rev a1)
Kernel Driver:
Results of find /dev -group video
/dev/dri/card0
/dev/dri/renderD128
/dev/fb0
What x.org is using:
Results of egrep -i " connected|card detect|primary dev|Setting driver" /var/log/Xorg.0.log
[    70.690] (--) NVIDIA(GPU-0): Acer X223W (CRT-1): connected
[    71.191] (--) NVIDIA(GPU-0): Acer X223W (CRT-1): connected
[    95.213] (--) NVIDIA(GPU-0): Acer X223W (CRT-1): connected
Linux OS:
Results of lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description:    Ubuntu 18.04.3 LTS
Release:        18.04
Codename:       bionic
IP Address:
Results of dig +short myip.opendns.com @resolver1.opendns.com
xx.xx.xxx.xxx
I have tried fixing this several times, but haven't been able to fix it. I do have the IP address.
karel
  • 122,292
  • 133
  • 301
  • 332
