I am new with Crontab and Linux. I am trying to schedule this following command line instruction in Crontab:
speedtest-cli --csv &>> /home/pi/speedtestLog.txt
I am trying doing it:
*/1 * * * * speedtest-cli --csv >> /home/pi/speedtestLog.txt 2>&1
But I am getting the error appended in the file:
/bin/sh: 1: speedtest-cli: not found
How do I resolve it please?
Some of the comments above are correct but they don't explain why.
The PATH environment variable is a list of filesystem paths that are searched for executable binaries, which usually looks like:
$ echo $PATH
/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin
The PATH variable is appended by the SHELL you are using. In ubuntu, /bin/sh links to the default shell, which is dash for system boot scripts (i.e. cron). Dash is similar to bash but not identical. In terminals, Bash is used by default.
On Debian-based systems (i.e. Ubuntu), PATH is initialized by pam_env based on the content of /etc/environment:
$ cat /etc/environment
PATH="/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games"
However, the shells like Dash/Bash also source /etc/profile and ~/.profile depending on how they are invoked (interactive vs login shell), where these scripts can append the PATH environment variable.
With all that said, speedtest-cli has to be in a folder on the PATH or you have to specify it using a full path. If you want option 1, you can try
*/1 * * * * . /home/pi/.profile ; speedtest-cli --csv >> /home/pi/speedtestLog.txt 2>&1
N.B. Thanks to steeldriver for pointing out that "source .profile" is a bashism and the posix standard is ". .profile".
Iyad K
  • 404
