I am using GNOME Ubuntu Desktop Environment. Right now I have to select the text and then right click on it and then have to select copy option, and the same is the case for paste as well.
Using PuTTY terminal from Windows, once you select any text, it'll be copied. And to paste it we will have to just right click. Can we do similar settings on Ubuntu as well?
Zanna
  • 72,312
you can do the double-click copy with a 3rd party app clipit
but the possible downside is it applies system wide not just gnome-terminal
sudo apt install clipit
when using Clipit:
  1. Right click on clipit icon in tray
  2. Preferences
  3. Settings
  4. check: Use Primary selections and Synchronize clipboards.
and you're good to go you can double click in terminal and it's in your clipboard
