To clean install Eclipse for C/C++ on Ubuntu 18.04 I tried sudo apt install eclipse eclipse-cdt. It's showing an error, see the log file....
log file.....
!SESSION Fri Aug 16 14:39:20 IST 2019 ------------------------------------------
!ENTRY org.eclipse.equinox.launcher 4 0 2019-08-16 14:39:20.065
!MESSAGE Exception launching the Eclipse Platform:
!STACK
java.lang.ClassNotFoundException: org.eclipse.core.runtime.adaptor.EclipseStarter
    at java.base/java.net.URLClassLoader.findClass(URLClassLoader.java:471)
    at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:588)
    at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:521)
    at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:626)
    at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
    at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
    at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
karel
  • 122,292
  • 133
  • 301
  • 332
Open the terminal and type:
sudo apt update
sudo apt install ubuntu-make g++
umake ide eclipse-cpp
To launch Eclipse click the Eclipse CPP icon in the Dash or launch Eclipse CPP from the terminal with the following command:
eclipse-cpp
On the first launch, you'll be asked to select the workspace directory. The default workspace directory should work just fine.
Cevelop is a free C++ IDE for professional developers which is based on Eclipse. Cevelop extends Eclipse CDT with many additional features: CUTE unit testing with Test Driven Development support, new refactorings and quick fixes, and much more.
To install Cevelop in all currently supported versions of Ubuntu open the terminal and type:
sudo snap install cevelop --beta --classic
karel
  • 122,292
  • 133
  • 301
  • 332
For the latest version the binary file name could be eclipse.
sudo add-apt-repository ppa:lyzardking/ubuntu-make
sudo apt-get update
sudo apt-get install ubuntu-make
umake  --list-available # check the list
Then check the binary file name: $HOME/.local/share/umake/ide/eclipse-cpp/ (default). Then write this to your .bashrc and good to go: export PATH="$HOME/.local/share/umake/ide/eclipse-cpp/:$PATH"
$ exec bash
$ eclipse
Zstack
  • 211
