I keep on getting this error when I try to install or upgrades and almost every thing.
After this operation, 731 kB disk space will be freed.
Do you want to continue? [Y/n] y
/bin/sh: 1: /usr/bin/apt-listchanges: not found
E: Sub-process /usr/bin/apt-listchanges --apt || test $? -lt 10 returned an error code (1)
E: Failure running script /usr/bin/apt-listchanges --apt || test $? -lt 10
Output for cat /etc/apt/apt.conf.d/20listchanges:
DPkg::Pre-Install-Pkgs { "/usr/bin/apt-listchanges --apt || test $? -lt 10"; };
DPkg::Tools::Options::/usr/bin/apt-listchanges::Version "2";
Output for sudo apt update && sudo apt upgrade:
     python3
     python3-crypto
     lsb-release
    E: Sub-process /usr/bin/dpkg returned an error code (
output for sudo apt update --fix-missing && sudo apt install -f
Hit:2 http://ftp.de.debian.org/debian sid InRelease
Hit:1 http://kali.download/kali kali-rolling InRelease
Hit:3 http://kali.download/kali kali-bleeding-edge InRelease
Reading package lists... Done
Building dependency tree
2 packages can be upgraded. Run 'apt list --upgradable' to see them.
0 upgraded, 0 newly installed, 0 to remove and 2 not upgraded.
1 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Setting up python3 (3.7.3-1) ...
running python rtupdate hooks for python3.7...
dpkg-query: package 'apt-listchanges' is not installed
Use dpkg --contents (= dpkg-deb --contents) to list archive files contents.
Traceback (most recent call last):
  File "/usr/bin/py3clean", line 210, in <module>
    main()
  File "/usr/bin/py3clean", line 196, in main
    pfiles = set(dpf.from_package(options.package))
  File "/usr/share/python3/debpython/files.py", line 53, in from_package
    raise Exception("cannot get content of %s" % package_name)
Exception: cannot get content of apt-listchanges
error running python rtupdate hook apt-listchanges
dpkg-query: package 'backdoor-factory' is not installed
    main()
Exception: cannot get content of backdoor-factory
error running python rtupdate hook backdoor-factory
dpkg-query: package 'dh-python' is not installed
    main()
Exception: cannot get content of dh-python
error running python rtupdate hook dh-python
dpkg-query: package 'gedit' is not installed
    main()
Exception: cannot get content of gedit
error running python rtupdate hook gedit
dpkg-query: package 'system-config-printer-common' is not installed
    main()
Exception: cannot get content of system-config-printer-common
error running python rtupdate hook system-config-printer-common
dpkg-query: package 'terminator' is not installed
    main()
Exception: cannot get content of terminator
error running python rtupdate hook terminator
dpkg-query: package 'veil' is not installed
    main()
Exception: cannot get content of veil
error running python rtupdate hook veil
dpkg-query: package 'virtualbox' is not installed
    main()
Exception: cannot get content of virtualbox
error running python rtupdate hook virtualbox
dpkg: error processing package python3 (--configure):
 installed python3 package post-installation script subprocess returned error
exit status 4
 python3
Raffa
  • 34,963
Option # 1:
Please try:
sudo apt purge -f apt-listchanges
Then try:
sudo apt install -f apt-listchanges
Option # 2:
Please try:
sudo dpkg --remove apt-listchanges
Then try:
Option # 3:
Please try:
sudo mv /etc/apt/apt.conf.d/20listchanges /etc/apt/apt.conf.d/20listchanges.bak
Then try:
Raffa
  • 34,963
